where to mount neg bat. cable alum head hemi? #1028531
07/08/11 07:58 PM
07/08/11 07:58 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
ok i asked in q n a but no responce so ask you guys
where the heck di ya mount the neg. battery cable on a hemi with alum heads?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: where to mount neg bat. cable alum head hemi? [Re: toplescuda] #1028532
07/08/11 08:07 PM
07/08/11 08:07 PM
California
mickm Offline
mickm  Offline
California
same place. i have mine on the front of the head, bolt hole up top close to the valve cover.
Re: where to mount neg bat. cable alum head hemi? [Re: toplescuda] #1028533
07/08/11 09:00 PM
07/08/11 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running a mid plate... mount it there(out
of the way)
Re: where to mount neg bat. cable alum head hemi? [Re: mickm] #1028534
07/08/11 10:42 PM
07/08/11 10:42 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
ok went back down and looked there is no bolt hole at all on the front of the driver head
no plates so that wont work either
didnt think alum would make a good ground???
intake,water pump and heads are alum.
1971 charger
Re: where to mount neg bat. cable alum head hemi? [Re: toplescuda] #1028535
07/08/11 11:42 PM
07/08/11 11:42 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Aluminum is an excellent conductor of electricity. Anywhere you can to 3/8" or larger bolt should be good.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: where to mount neg bat. cable alum head hemi? [Re: toplescuda] #1028536
07/08/11 11:49 PM
07/08/11 11:49 PM
Due to dissimilar metals and the corrcosion that can occur in electrcical circuits do to that I would install it onto the block and not the heads Maybe ground the motor to the frame off of the bottom 7/16 bellhousing bolts, the ones on the bottom ears
Re: where to mount neg bat. cable alum head hemi? [Re: Cab_Burge] #1028537
07/08/11 11:59 PM
07/08/11 11:59 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I ground my neg. to the frame and run a ground from each aluminum head to the side of the aluminum block then to the frame again per MSD inst..
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: where to mount neg bat. cable alum head hemi? [Re: MRMOPAR622] #1028538
07/09/11 12:48 AM
07/09/11 12:48 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
This is the only way you want to do aluminum headed engine with a nasty ignition....Each head must be grounded....Otherwise the coil wire will arc to the head or anything close to it.
Re: where to mount neg bat. cable alum head hemi? [Re: Dragula] #1028539
07/09/11 12:56 AM
07/09/11 12:56 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
i will redo it but i needed to bump motor over to do the converter bolts so right now it to the top power stearing pump bolt
1971 charger
Re: where to mount neg bat. cable alum head hemi? [Re: toplescuda] #1028540
07/09/11 12:31 PM
07/09/11 12:31 PM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
It should be grounded to the frame in the trunk, where the battery is supposed to be located.
Re: where to mount neg bat. cable alum head hemi? [Re: Dragula] #1028541
07/10/11 10:52 PM
07/10/11 10:52 PM
Mt. Eden Ky.
Mt. Eden Ky.
I am sure that there is a good explanation for this, but... why is this necessary with the contact of every head bolt joining the heads to the block ?
1996 Ram 1500 Sport
1968 road runner
Re: where to mount neg bat. cable alum head hemi? [Re: Hemi Allstate] #1028542
07/10/11 11:15 PM
07/10/11 11:15 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
Run ground to front and attach it to bell housing or block and to each head and intake and frame. if battery is in trunk never ground to frame in back and front too. From hours of chasing down problems this is what worked for me.
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: where to mount neg bat. cable alum head hemi? [Re: 526ciduster] #1028543
07/10/11 11:29 PM
07/10/11 11:29 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have never heard of '"not to ground back and front " Reason why? enquiring minds want to know. And for the grounding of the heads
Re: where to mount neg bat. cable alum head hemi? [Re: rowin4] #1028544
07/10/11 11:40 PM
07/10/11 11:40 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
static loop. and also any part that shifts with heat and expansion should have a groung by itself. using a frame by itself for ground is never a good idea. I dont want to get into pee pee match but this is coming from some of the fastest in the business that have experienced the problem that high output ignitions can provide through bad grounds.
Re: where to mount neg bat. cable alum head hemi? [Re: Dragula] #1028545
07/11/11 12:13 AM
07/11/11 12:13 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
the primary reason both heads are grounded is for the spark plugs. Composite head gaskets can reduce the quality of their ground.
home of the
Sox and Martin Hemi Duster
Re: where to mount neg bat. cable alum head hemi? [Re: HEMIFRED] #1028546
07/11/11 12:51 PM
07/11/11 12:51 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
ok guys the only reason i asked is cause MY heads do not have a lug or bolt hole to mount a battery cable to
i was always under the impression that alum dont make as good of ground as steel
i had to ground it on the power steer bracket wich does not look clean to me and i want to (and will) find a differnt spot to ground it
as far as running a wire to each head??? does it not have 17bolts doing just that??
(alum head iron block)
1971 charger
Re: where to mount neg bat. cable alum head hemi? [Re: toplescuda] #1028547
07/11/11 12:56 PM
07/11/11 12:56 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
..motor on the left
1971 charger
Re: where to mount neg bat. cable alum head hemi? [Re: rowin4] #1028548
07/11/11 01:03 PM
07/11/11 01:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Many of the wiring system suppliers (Painless, Ron Francis, etc.) recommend against using the frame as the battery ground, too many joints that might not be making good contact. They recommend running a ground cable (same gauge as the power cable) directly to the block then another from there to the body.
Re: where to mount neg bat. cable alum head hemi? [Re: John_Kunkel] #1028549
07/11/11 01:20 PM
07/11/11 01:20 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
this is what iv been working on....angies 74challenger now with a 426 hemi
lil sollid roller (600),alum rod,landy heads
will get the tunnel ram back on it i just wanted to fire it up get timing where i wanted it then switch it over
not sure how pic will show up as did with the phone
1971 charger
Re: where to mount neg bat. cable alum head hemi? [Re: toplescuda] #1028550
07/11/11 01:23 PM
07/11/11 01:23 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
to the head can also include using an intake or exhaust bolt.
home of the
