Am I OVER-GEARED #1028447
07/08/11 05:34 PM
07/08/11 05:34 PM
HOUSTON,TEXAS
FIREGUY12 Offline OP
HOUSTON,TEXAS
Here is the scoop trying to decide which way to go on the next gear. Here is the current combo
3000 lbs. 71 duster
454 ci small block mopar
powerglide 1.80 first gear
8 inch converter 5300 stall
4.56 Rear gear
14x32 tire with a 105 roll out
1050 dominator
crosses at 6500 Rpm
H.P. according to dyno sheet
633 h.p. at a low 5700 rpm
650 ft. lbs torque @ 4600 rpm
Shift ay 6500 rpm
Ran
1.41 60 ft
4.11 330ft
6.41 1/8 th
8.40 1000ft
10.11 1/4
131.43 mph
Since I broke the case on the glide thinking about changing the 1.80 gear set to a 2.08 or 2.11 while its down in hopes of picking up the 60 ft.
This engine is difficult to run due to its unusual power band. Any suggestion moparts. Is this a good move or should I go up on the rear end gear?
http://www.youtube.com/watch?v=QQZQsoXCpvA
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028448
07/08/11 05:41 PM
07/08/11 05:41 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I am no help on the gear. But I am curious what heads are on your motor? Jim
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028449
07/08/11 05:43 PM
07/08/11 05:43 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I think you have the right gear, but are down on HP. What heads are you running and flow numbers please?
Re: Am I OVER-GEARED [Re: camastomcat] #1028450
07/08/11 05:46 PM
07/08/11 05:46 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
Brodix B1/BA M/C heads I bought this engine from a member here. All I know is Koffels Place built this engine some years ago. I dont have any flow numbers other than whats on brodix site.
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028451
07/08/11 05:57 PM
07/08/11 05:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your a couple hundred RPM over what max should be...
as a rule of thumb you want to cross the line 10%
over peak HP RPM... which in your case would be 6300
or so... big torque engines can use less than 10% so
it can pull harder
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028452
07/08/11 05:57 PM
07/08/11 05:57 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I'm not a small block guy but I run the B1 original heads and have run them on a 470 BB. That motor made around 800HP. I would think the Koffel heads should do the same on your combo with an average port job, 360+ intake flow, and 32* of timing. I am also sure someone else here is more qualified to talk about B1/BA MC's and small block power numbers. The MPH and ET look right for 10.0's and 131 and 650HP. If you go to a taller gear, 4.10's or something, it will slow down IMO.
Re: Am I OVER-GEARED [Re: MR_P_BODY] #1028453
07/08/11 06:00 PM
07/08/11 06:00 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
it can pull harder
It seems wrong that it makes more tourqe than HP?
Re: Am I OVER-GEARED [Re: camastomcat] #1028454
07/08/11 06:02 PM
07/08/11 06:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
it can pull harder
Not really
Re: Am I OVER-GEARED [Re: MR_P_BODY] #1028455
07/08/11 06:04 PM
07/08/11 06:04 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
What about the 2.08 first gear versus the current 1.80. do you think that will help the 60 ft.
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028456
07/08/11 06:07 PM
07/08/11 06:07 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
It might, but I think they are weaker in strength. Are they going to be straight cuts?
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028457
07/08/11 06:10 PM
07/08/11 06:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A 2.08 would help in the 60' IF you dont loose traction...
you would gain more torque with them.... are you sure
your chassis is working the best it can
EDIT
I think you have a bit too much stall on the conv...
your well past peak torque and its falling at higher revs
Re: Am I OVER-GEARED [Re: camastomcat] #1028458
07/08/11 06:10 PM
07/08/11 06:10 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
I will definetly go with straight cuts.
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028459
07/08/11 06:10 PM
07/08/11 06:10 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I think that the 14x32's are a big tire to pull on the top end. If it will hook? It might go faster with a 12x29 Gdyr and a 4.10 gear. JMO Jim
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028460
07/08/11 06:14 PM
07/08/11 06:14 PM
HOUSTON,TEXAS
HOUSTON,TEXAS
Actually i have not touched the chassis at all. I think i can tweaked the rear shock a little and maybe add some weight to the rear say 100 lbs. The car is nose heavy. The added weight would make the car almost 50/50.
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028461
07/08/11 06:37 PM
07/08/11 06:37 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
you know what mr.p said makes alot of since to me ...about the verta to big....i had a 340 with a small solid cam and ported heads and i changed everything i could think of to make the car 60' even the verta but i went to a smaller verta(8") from a 9.5 5000 the 8" was a 5600 car didnt lose any but didnt gain a thing....now that i think about it if i would have put maybe a 4000/4500 or even a 3800 car may have been alot better then it was...something to think on...sorry for the hi jack just had to share my ex. mike
Re: Am I OVER-GEARED [Re: earthmover] #1028462
07/08/11 10:09 PM
07/08/11 10:09 PM
Guitar Jones Offline
Wow, 650 at 4600? You have way too much converter. I'd use about a 4400 with a 1.76/1.80 glide. You don't need more 1st gear, you have the torque to pull that 1.80 gear, you just need to get the engine in that powerband.
You could probably use less gear in the rear as well. With that torque I wouldn't be surprised if it ran the same shifting at 6000.
I should add that I use a 4200 converter. Before with the 340 I was using a 4600 but I have a low gear 904 so I'm sure that helps make up for any lack of stall speed.
Re: Am I OVER-GEARED [Re: Guitar Jones] #1028463
07/08/11 10:44 PM
07/08/11 10:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Why did the tranny case break. I've gone 8.50's with stock powerglide cases and others have gone a lot faster than that. How's the pinion angle.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Am I OVER-GEARED [Re: pittsburghracer] #1028464
07/09/11 12:14 AM
07/09/11 12:14 AM
HOUSTON,TEXAS
HOUSTON,TEXAS
In a back half car the cars tend to twist even thou you may not see it. I run a front engine plate and a mid plate. The tranny is bolted down to the trans crossmember. So when the chaasis flexes the weakess point break. On a poweglide the stock cases are weak. I have the JW bell housing and tail shaft. Glides tend to crack right above the shifter arm as mine did. I should have not bolted the tail housing down and the tranny could have move with the chassis and not broke. I will upgrade to an aftermarket case to fix this problem.
Re: Am I OVER-GEARED [Re: FIREGUY12] #1028465
07/09/11 12:23 AM
07/09/11 12:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you using a solid trans mount with a front and
mid plate.... use a stock rubber trans mount
Re: Am I OVER-GEARED [Re: MR_P_BODY] #1028466
07/09/11 12:27 AM
07/09/11 12:27 AM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
