Re: NHRA/IHRA rules on modified/changed firewalls..??
[Re: Alan Warman]
#1028431
07/08/11 08:04 PM
07/08/11 08:04 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
General Regulation
7:4 FIREWALL Each car in competition must be equipped with a minimum .032- inch aluminum or .024-inch steel firewall, extending from side to side of the body and from the top of the engine compartment’s upper seal (hood, cowl, or deck) to the bottom of the floor and/or bellypan. Firewall must provide a bulkhead between the engine and/or fuel tank and driver compartment. All holes in firewall must be sealed with aluminum or steel. In certain instances, fiberglass, carbon fiber, or other composites may be used. See Class Requirements or consult NHRA. Use of magnesium prohibited.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 52savoy]
#1028434
07/10/11 03:10 AM
07/10/11 03:10 AM
Posts: 30,449 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Well ...I should check-in on my own topic ....... ...THX guyz ...... This situation is on my Caravan project ....I am going to set the motor back INTO the driver's compartment ...like near where the normal front-seating is ...and then drive-it from the typical second seating location....using the driver and passenger rear slider doors to enter and exit the vehicle. Does this change anything here ? ANY other thoughts ?
[Re: dOoC]
#1028435
07/10/11 07:35 AM
07/10/11 07:35 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'd move the driver seat up further..otherwise you'll end up with a real long steering column.
[Re: dOoC]
#1028437
07/10/11 05:23 PM
07/10/11 05:23 PM
Posts: 20,184 Park Forest, IL
slantzilla
Park Forest, IL
You'll have to build a dog house out of .024 steel or .032 aluminum. You'll also have to cage it because the firewall/floor is modified.
[Re: dOoC]
#1028439
07/10/11 09:16 PM
07/10/11 09:16 PM
slantzilla
Park Forest, IL
If it's only going to run high 11's you might get away w/o a cage. Personally I'd want at least an 8 point with all that glass area around me.
Depending on how big the firewall/doghouse end up being I'd think the weight difference would be in the 20# range.
There used to be a guy on the board with a Caravan that had a small block in the pretty much stock location. I think his name was 'Scaredvan' or something like that.
