Re: Ignition switch replacement
[Re: Andrewh]
#1028419
07/08/11 04:34 PM
07/08/11 04:34 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I just changed it on my '68. I used a pair of needle nose plyers. The tips fit into one set of the opposing slots, and it screwed right out.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: pleasantk]
#1028421
07/08/11 05:28 PM
07/08/11 05:28 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Heavy snap ring pliers work great also.I have SnapOn that can either expand or contract depending where you put them together.Rocky
Chrysler Firepower
[Re: pleasantk]
#1028422
07/08/11 06:16 PM
07/08/11 06:16 PM
Posts: 252 L.A., CA
plysat
L.A., CA
Thanks for the tips! I will try the needle nose trick tonight when I get home.
Thanks, Rob
FWIW, I put a bit of electrical tape on the plier tips to avoid scratching the nut when I did mine...
