Hood black out paint ? again #1028289
07/08/11 11:00 AM
07/08/11 11:00 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I have a 1972 340 4speed Cuda currently being painted. The car is a factory optioned V21 blackout hood car. I would like as correct as an appearance as possible but also not have to worry about getting wax on the black paint. Here is the last thread https://board.moparts.org/ubbthreads/show...rue#Post6643220 I am wondering about a mat clear used on a light type texture paint? Has anyone done this?
Re: Hood black out paint ? again [Re: UCUDANT] #1028290
07/08/11 01:11 PM
07/08/11 01:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
When I did the hood black out on my 72 Cuda, I used Mar-Hyde textured black,...IIRC it's made by PPG, the less reduction when spraying, the more texture, you can wax it with no issues if you want
Re: Hood black out paint ? again [Re: DAYCLONA] #1028291
07/08/11 03:29 PM
07/08/11 03:29 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks, I just need to be able to tell the painter how much texture is correct, then he can test shoot a practice panel (after the red cures). So can anyone help me with the proper amount of texture...either a good pic, desciption or even mixture amounts that produce the desired effect. Any info on the technique used to shoot it for the desired result would be good ie HVLP gun, pressure patern distance etc.
Re: Hood black out paint ? again [Re: DAYCLONA] #1028292
07/08/11 03:32 PM
07/08/11 03:32 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Do you have pics of tht car? I'd love to see it. Especially the hood
Re: Hood black out paint ? again [Re: UCUDANT] #1028293
07/08/11 08:52 PM
07/08/11 08:52 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
So is this about right?
Re: Hood black out paint ? again [Re: UCUDANT] #1028294
07/08/11 08:52 PM
07/08/11 08:52 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
another at a further distance
Re: Hood black out paint ? again [Re: UCUDANT] #1028295
07/12/11 08:19 AM
07/12/11 08:19 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I need the 72 Factory Service Manual paint chart from the Refinishing Procedures section. This is to determine if the black out hood paint was organisol in 72.
The attached paint chart shows flat black exterior paint, but no mention of organisol textured paint? What did the 1970 paint chart (AAR Cuda) show?
Re: Hood black out paint ? again [Re: UCUDANT] #1028296
07/13/11 07:58 AM
07/13/11 07:58 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Someone please help me clarify if the hood paint was organisol
Re: Hood black out paint ? again [Re: UCUDANT] #1028297
07/13/11 12:41 PM
07/13/11 12:41 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
The 1970 paint chart (think AAR organisol hood) shows a black velvet paint?
Re: Hood black out paint ? again [Re: UCUDANT] #1028298
07/13/11 02:10 PM
07/13/11 02:10 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I believe "Black Velvet" is the interior paint used for dash, steering column etc. for 1970.
Re: Hood black out paint ? again [Re: 6pkaar] #1028299
07/13/11 04:26 PM
07/13/11 04:26 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 70 Plymouth Factory Service Manual.
Re: Hood black out paint ? again [Re: 6pkaar] #1028300
07/13/11 05:24 PM
07/13/11 05:24 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
X9 paint is X9. it is called different names, in each model year, but it's still black. each division had a different name for it, same as the rest of the colors. black is black velvet , black diamond, formal black, etc. it's not used on a hood, unless you have a x9 car.
Re: Hood black out paint ? again [Re: UCUDANT] #1028301
07/13/11 06:48 PM
07/13/11 06:48 PM
Plainfield, Il.
cuda72 Offline
cuda72  Offline
Plainfield, Il.
The original hood treatment didn't have quite as much texture, but this looks sooo much better than the original paint. If you are looking for perfect originality, the texture is too much. However, the paint shown will be MUCH easier to keep looking good (especially when it comes to getting wax on it).
Re: Hood black out paint ? again [Re: cuda72] #1028302
07/13/11 09:44 PM
07/13/11 09:44 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks again guys. I really needed this info and you all are AWESOME.
Has anyone done this in enamel? I'll need to convert it into a useable enamel code... my car is shot in enamel
Re: Hood black out paint ? again [Re: UCUDANT] #1028303
07/13/11 11:53 PM
07/13/11 11:53 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Take the paint code to the paint supply store and see if they have a crossover number from the lacquer paint to enamel.
Reading this it sounds like the single stage urethane code is dcc 9355.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
