Ignition timing #1028199
07/08/11 06:57 AM
07/08/11 06:57 AM
Indiana
65dragnet Offline OP
Indiana
Put an rb engine together runs fine but can't get anymore than 30 degrees timing in it. Any ideas ? thanks
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Ignition timing [Re: 65dragnet] #1028200
07/08/11 08:12 AM
07/08/11 08:12 AM
N.E. Ohio
6bblFLASH Online content
6bblFLASH  Online Content
N.E. Ohio
Need more of an explanation please
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Ignition timing [Re: 65dragnet] #1028201
07/08/11 09:03 AM
07/08/11 09:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Cant you turn it any farther... if thats the case...
pull the dist and rotate the intermediate shaft 1 or
2 teeth and reassemble
Re: Ignition timing [Re: MR_P_BODY] #1028202
07/08/11 01:26 PM
07/08/11 01:26 PM
Re: Ignition timing [Re: Cab_Burge] #1028203
07/08/11 05:09 PM
07/08/11 05:09 PM
Indiana
Indiana
negative on the intermediate shaft that's not the problem the engine just won't take any advance past 30 degrees. Degreed cam at 106 it is a Comp 324 650 flat tappet, I know it should be 108 but thought I'd try a little advance. Surely two degrees isn't going to cause this. If I advance the timing past 30 to 36 it will choke the engine down and die. TDC and timinng mark on fluid damper are right on. I've had to miss something this is real embarassing and is making me feel very stupid
Re: Ignition timing [Re: 65dragnet] #1028204
07/08/11 05:38 PM
07/08/11 05:38 PM
Az
Crizila Offline
Crizila  Offline
Az
Assume you are setting the total with all the mechanical in ( at or around 3K). Only other issues are the timing marks are off or the cam isn't in properly. Might want to check TDC on the the dampener with a positive stop in the #1 hole first - pull all the plugs, DISCONNECT the battery, and rotate the engine by hand - gently.
Fastest 300
Re: Ignition timing [Re: Crizila] #1028205
07/08/11 05:43 PM
07/08/11 05:43 PM
Indiana
Indiana
Thanks did that already that's how I know marks are correct, I don't want pull front cover again but it looks like it's going to happen. Ran this combo before and took it apart for it's 6 year freshen up and decided to mess with cam centerline. What a dummy ! I'm frustrated and this heat is killing my old butt LOL
Re: Ignition timing [Re: 65dragnet] #1028206
07/08/11 05:47 PM
07/08/11 05:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you using a MSD ignition... the dist wires could
be backwards
Re: Ignition timing [Re: MR_P_BODY] #1028207
07/08/11 06:08 PM
07/08/11 06:08 PM
Indiana
Indiana
yes it's a 6 al but I think the plug in is idiot proof but I'll check thanks Mike
Re: Ignition timing [Re: 65dragnet] #1028208
07/08/11 06:17 PM
07/08/11 06:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2 degrees of cam timing wouldnt effect the spark timing
I'm just throwing out ideas... if you didnt change any
of the ignition stuff it SHOULD be fine
Re: Ignition timing [Re: MR_P_BODY] #1028209
07/08/11 06:25 PM
07/08/11 06:25 PM
Indiana
Indiana
AGREE
Re: Ignition timing [Re: 65dragnet] #1028210
07/08/11 08:40 PM
07/08/11 08:40 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Ebert did you advance the cam with a bushing and the same timing gears. Or did you change it with the gear with the different marks on it. Something sounds mighty funny,hope you get her fixed. I will see you at the hill if your coming tomorrow.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Ignition timing [Re: moparmxz] #1028211
07/08/11 08:58 PM
07/08/11 08:58 PM
Indiana
Indiana
Randy I advanced it with the three keyed gear, no bushing
Re: Ignition timing [Re: 65dragnet] #1028212
07/08/11 09:08 PM
07/08/11 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And you did verify it with a degree wheel... correct
Re: Ignition timing [Re: MR_P_BODY] #1028213
07/08/11 09:17 PM
07/08/11 09:17 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Those little marks can be tricky,i would pull it back apart and double check,but as mr P say,s it would be best to do it with a degree wheel.
Re: Ignition timing [Re: 65dragnet] #1028214
07/08/11 11:46 PM
07/08/11 11:46 PM
If you DID NOT use a degree wheel and verify the actual cam timing and lobe seperation angles you will never know what the cam is in at I have seen many crankshaft and cam gears with multiple keyways be off as many as 12 degrees I just went thruogh this with a high doller nine key way timing set that the 6 degree advance keyway was actually 2 degrees advanced on the cam, not six You have to check everything to make sure it is correct I had a very similar expereince with the first roller cam I installed years ago, the cam pin was installed 8 degrees retarted It ran fine on the trailer, it was a 392 Hemi V drive boat motor, rev and sounded like it was a SB Chevy, in the water it wouldn't fall out of a tree if you pushed it with a D8 CAT , horrible experience Let us know what you find
Re: Ignition timing [Re: Cab_Burge] #1028215
07/09/11 12:27 AM
07/09/11 12:27 AM
Indiana
Indiana
Yes fellas I did degree the cam with a degree wheel and I know for a fact that the key way in the Eagle crank is off 2 degrees . I installed the cam with the intake ctr line method , straight up and it ended up being 106 which is advanced 2 degrees from the cam recommended 108. But something is bad wrong with my approach , I screwed up some where. I have never ran into this in the 40 years I've been wrenching , getting too old I guess ,it's coming apart tomorrow. Thanks guys
Re: Ignition timing [Re: 65dragnet] #1028216
07/09/11 02:17 AM
07/09/11 02:17 AM
Before you move the cam timing check the exhaust lobe center, if your cam is ground on a 108 lobe center then the exhaust lobe center should be in at 110 BTDC with the intake in at 106 ATDC I have seen more than one cam ground incorrectly Murphy really likes to mess with us racers Good luck, take your time and find out what you can, let us know what you find, this one is puzzling
Re: Ignition timing [Re: Cab_Burge] #1028217
07/10/11 12:17 AM
07/10/11 12:17 AM
Indiana
Indiana
Well pulled it back apart guys and checked all events of the cam with a degree wheel, it was absolutely perfect. Checked distributor wires checked rotor , this a pro billet MSD and is locked at full advance, found no issues. Checked balancer and it was within 1 degree at absolute TDC. Cam was actually installed straight up and came in at 109 we left everything as was and buttoned it back up.Fired it up and it timed at 36 degrees , wow what a PITA. I know I'm not crazy but more of this crap and I'll be there. Sorry guys don't know what happened. I have two witnesses that experienced this and they are stunned also. Simply un friggen believable. Thanks for all the input !
Re: Ignition timing [Re: 65dragnet] #1028218
07/10/11 08:11 AM
07/10/11 08:11 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Glad to hear it is ok now and if your like most of us it will keep you awake a few nights wondering what the friday was going on.
