Re: Dodge truck- feels like something loose in front end
[Re: Joesixpack]
#1027502
07/07/11 09:55 AM
07/07/11 09:55 AM
Posts: 5,797 minnarusta
TX9H6E4CUDA
minnarusta
Track bar........get it fixed with a very good replacement piece. My truck did the same exact symptoms and had it replaced. The shop kept sticking cheepies in and they kept going bad. Finally one failed out of the blue and I hit a parked car with my truck. Get a good quality piece.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
[Re: Carsavior]
#1027507
07/07/11 04:41 PM
07/07/11 04:41 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
What is a trackbar exactly?
It locates the front axle, it connects on the passenger side of the axle and goes at an angle up to the drivers side frame rail , it's a known weak point. they usually start going bad well before 100k , I ekked 99.9k out of my first one and 127 out of the current one. telltale sign is having to continually correct to keep going in a straight line.
I get tired of that after 20k miles or so and finally change it
[Re: Carsavior]
#1027511
07/08/11 09:30 AM
07/08/11 09:30 AM
JohnRR
On a 2 wheel drive? I don't remember seeing anything like that under there-
You didn't say it was a 2 wheel drive, I just ASSuME that most Cummins powered trucks are 4 wheel drive .
Have you checked the shaft that goes from the steering column to the steering box , that one is making a lot of clunking on mine , which is a 4x4 , also check the swaybar endlinks as stated above, I had one that the ball end separated and made an awful rattling I could nevermind.
[Re: dennismopar73]
#1027513
07/08/11 09:38 PM
07/08/11 09:38 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
My '01 4x4 auto only has 34k on it, and it even has a slight steering wheel jiggle on rough roads, and it does wander a little. The spring at the bottom of the column has practically no play in it, but I can imagine 10 years on a cheap ball bearing with little grease, it is probably starting to wear out.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
