Know where I can buy a carbide burr like this one? #1027336
07/06/11 06:50 PM
07/06/11 06:50 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I saw it in an older Steve Dulcich article and it looks like it would be handy for the port matching exercise I need to do on my welded-up intake runners.
Re: Know where I can buy a carbide burr like this one? [Re: BradH] #1027337
07/06/11 06:53 PM
07/06/11 06:53 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
McMaster Carr sells everything
Re: Know where I can buy a carbide burr like this one? [Re: Deepockets] #1027338
07/06/11 07:34 PM
07/06/11 07:34 PM
BradH Offline OP
BradH  Offline OP
Not that one... (I just looked at their online catalog).
I suspect this was somebody's (Roger Helgesen) custom burr and not typical of what most suppliers offer. I'm sure I have something already that'll work, but thought the one pictured above would be better suited to a specific job I have to complete.
Re: Know where I can buy a carbide burr like this one? [Re: BradH] #1027339
07/06/11 07:52 PM
07/06/11 07:52 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Check your Pms.
RIP Monte Smith
Re: Know where I can buy a carbide burr like this one? [Re: CompWedgeEngines] #1027340
07/06/11 07:56 PM
07/06/11 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check your Pms.
If you know where to get it please post it and not
just in a PM... thanks
Re: Know where I can buy a carbide burr like this one? [Re: CompWedgeEngines] #1027341
07/06/11 07:57 PM
07/06/11 07:57 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
SD is on here from time to time ....send him a PM.
Re: Know where I can buy a carbide burr like this one? [Re: BradH] #1027342
07/06/11 07:59 PM
07/06/11 07:59 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Did you try Grainger? They sell single cut, flame end burrs, just not sure if they're that long.
Edit...Try this web page
Re: Know where I can buy a carbide burr like this one? [Re: BradH] #1027343
07/06/11 08:09 PM
07/06/11 08:09 PM
USA eastern PA
340Bird Offline
340Bird  Offline
USA eastern PA
MSC will have it. The listing for burrs has like 1900 differant ones.
web page
Bird....
Re: Know where I can buy a carbide burr like this one? [Re: 340Bird] #1027344
07/07/11 01:54 PM
07/07/11 01:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Enco and Rutland Tool have better deals than Grainger or McMasterCarr.
That flute spacing looks like aluminum vs a cast iron cutter?
Re: Know where I can buy a carbide burr like this one? [Re: autoxcuda] #1027345
07/07/11 02:15 PM
07/07/11 02:15 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Know where I can buy a carbide burr like this one? [Re: BradH] #1027346
07/07/11 02:21 PM
07/07/11 02:21 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Know where I can buy a carbide burr like this one? [Re: sixpackgut] #1027347
07/07/11 02:31 PM
07/07/11 02:31 PM
Missouri, Cole county
gbolten480 Offline
gbolten480  Offline
Here is a page from out of the ENCO catalog.
http://www.use-enco.com/CGI/INPDFF?PMPAGE=251&PMCTLG=00
The tricky thing may be the shank length - I believe most of these are shorter - though it should give a good starting point. Hope it helps, in your search.
Re: Know where I can buy a carbide burr like this one? [Re: gbolten480] #1027348
07/07/11 05:09 PM
07/07/11 05:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All my burrs are 6" except one.... its a special made
12" OAL that I got from one of the guys in the head
porting lab at work
Re: Know where I can buy a carbide burr like this one? [Re: MR_P_BODY] #1027349
07/07/11 05:18 PM
07/07/11 05:18 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Re: Know where I can buy a carbide burr like this one? [Re: BradH] #1027350
07/07/11 05:21 PM
07/07/11 05:21 PM
Az
Crizila Offline
Crizila  Offline
Az
Kinda dull in color to be carbide??
Fastest 300
Re: Know where I can buy a carbide burr like this one? [Re: Crizila] #1027351
07/07/11 08:38 PM
07/07/11 08:38 PM
Winter Park, Florida
classracer Offline
classracer  Offline
I get some of the burrs I use from BLP Products here in Orlando. I get some special or custom burrs from Mondello Performance in Tenn.
70 Challenger A/SA 2441
Re: Know where I can buy a carbide burr like this one? [Re: BradH] #1027352
07/08/11 03:10 AM
07/08/11 03:10 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Brad .... just to be 100% "correct" in the description of this part(I am surprised that no-one has mentioned this earlier-I furgot to) ...
what you have pictured is a carbide CUTTER ... not a burr. A cutter will tend to walk-around on you(muchO more than a burr) .... and if that happens in the port and then starts banging-around ... it could either severely bend the shank of the cutter ... or/AND damage your grinder..
