mirror template #1027309
07/06/11 03:38 PM
07/06/11 03:38 PM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
If anyone has a door from a 1967 GTX ,Satellite. Belevede, that had a mirror on the right side could you make me a template so I know the location on where to mount it.Please leave me a message if you can make one.Or make one from the left side and I can just flip it over.
Thanks in advance
Re: mirror template [Re: 1967GTX440] #1027310
07/06/11 06:59 PM
07/06/11 06:59 PM
L.A., CA
P
plysat Offline
plysat  Offline
P
L.A., CA
FWIW, I installed an RH mirror on my 68... Took off the LH mirror, measured the location of the holes relative to the door edge/window frame, and just drilled em in the "mirror image" spot on the right side. Worked fine...
Re: mirror template [Re: plysat] #1027311
07/08/11 10:35 AM
07/08/11 10:35 AM
Ontario,Canada
Ontario,Canada
Yes I am trying to avoid taking the driver door apart I thought if some one had an old car door around they could just make me a template.If not I will take my door apart and make one.
Re: mirror template [Re: 1967GTX440] #1027312
07/08/11 02:55 PM
07/08/11 02:55 PM
L.A., CA
P
plysat Offline
plysat  Offline
P
L.A., CA
It's pretty easy... I assume you've done it before, but if not ... just remove a few screws and/or hex bolts to take off the inner handles, big flathead screwdriver (or the proper tool ) to carefully pop the door panel clips, if the moisture barrier is still there carefully untape it and fold it up outta the way (may need to put new tape on it when ya put it back)... from there, with the window up, it's EZ to unbolt the mirror with a socket and extension.
