1970 Charger Refueling Problem #1026529
07/05/11 04:27 PM
07/05/11 04:27 PM
Charlotte
V
Vainglory Offline OP
Voice of Reason
Voice of Reason
V
Charlotte
Lately I have been having what seems like a unique problem with my '70 Charger. When I put gas in, rather than flowing smoothly into the tank, it accumulates in the fuel filler neck. Note that this is a newly-installed tank and filler neck, so there might be some problem with the installation.
However, I'm interested to know if anyone has had or heard of this kind of issue before. Do you think there is some obstruction in the fuel filler neck? How would I go about determining what that obstruction might be? Any tips or tricks that I might use short of dropping the gas tank? I'd like to avoid a major project if at all possible.
Re: 1970 Charger Refueling Problem [Re: Vainglory] #1026530
07/05/11 04:29 PM
07/05/11 04:29 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
check to be sure the vent tube isn't squished
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 1970 Charger Refueling Problem [Re: amxautox] #1026531
07/05/11 07:57 PM
07/05/11 07:57 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I get this same thing with my 70. I almost have to stand next to the car during the entire fill up because the nozzle keeps clicking off. Quite annoying. My fuel system is entirely new and restored to stock with the exception of using a larger fuel sender.
Re: 1970 Charger Refueling Problem [Re: amxautox] #1026532
07/05/11 08:54 PM
07/05/11 08:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said.....i'd bet a venting issue
Coming soon!!!!
Re: 1970 Charger Refueling Problem [Re: Mr.Yuck] #1026533
07/05/11 10:39 PM
07/05/11 10:39 PM
Charlotte
V
Voice of Reason
Voice of Reason
V
Charlotte
Looks like you guys were right, at least about the fact that it's a venting issue. The vent tube is not squished - it's not there at all!
I apologize if this seems elementary, especially for someone with as many posts as I have, but I do appreciate your help. I basically got this car exactly as it is, and very recently at that, with all of the kinks clearly not worked out. It was supposed to be "done," but apparently that means different things to different people.
In any case, I think it's time to dig out my factory service manual and figure out how to put this vent tube on. I have another request. Here are pictures of my trunk - could someone post some pictures of what it's supposed to look like?
And if someone has pictures of an install of a vent tube, that would be ideal.
Also, is this ( http://www.yearone.com/serverfiles/fbsho...earchid=5871866 ) the correct part? Is there somewhere other than Year One that I should order from?
Re: 1970 Charger Refueling Problem [Re: Vainglory] #1026534
07/05/11 10:39 PM
07/05/11 10:39 PM
Charlotte
V
Voice of Reason
Voice of Reason
V
Charlotte
Another picture of the trunk
Re: 1970 Charger Refueling Problem [Re: Vainglory] #1026535
07/05/11 10:40 PM
07/05/11 10:40 PM
Charlotte
V
Voice of Reason
Voice of Reason
V
Charlotte
Another picture of the trunk.
Re: 1970 Charger Refueling Problem [Re: Vainglory] #1026536
07/05/11 10:40 PM
07/05/11 10:40 PM
Charlotte
V
Voice of Reason
Voice of Reason
V
Charlotte
And last one.
Re: 1970 Charger Refueling Problem [Re: Vainglory] #1026537
07/06/11 11:54 AM
07/06/11 11:54 AM
Charlotte
V
Voice of Reason
Voice of Reason
V
Charlotte
Anybody have pictures of what it's supposed to look like?
Re: 1970 Charger Refueling Problem [Re: Vainglory] #1026538
07/06/11 12:05 PM
07/06/11 12:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
take a piece of brake line 3/16" I think. Run it along the side of the filler neck (where those clips are) It runs thru the gasket and extends maybe an inch below the trunk. The top has a short pice of hose that attaches to a nipple under your gas cap. Stick your head in and take a look.
Re: 1970 Charger Refueling Problem [Re: Mr.Yuck] #1026539
07/06/11 12:16 PM
07/06/11 12:16 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
The vent tube runs from the top of the filler neck tube where it meets the quarter panel and dumps off into the inner framerail next to the filler neck tube. I seriously don't think it plays into the filling process since it doesn't even touch the tank and the pump nozzle is more than surely pass the exit point of the filler neck tube (nipple connection for vent tube at top). It's main function would be venting when the gas cap is closed.
I have always had this issue with all my 2nd generation Chargers and I've owned them for over 30 years now. I never leave the pump on auto. Sometimes it is the position of the nozzle outlet in the filler tube. I always hold mine such that the tip of the nozzle is against the outboard side the filler tube, not just sitting in there. It is a pain in the butt, but sure beats having to clean all the fuel spillage off the quarter.
Troy
Houston Mopar Connection Club
Re: 1970 Charger Refueling Problem [Re: hemi68charger] #1026540
07/06/11 12:58 PM
07/06/11 12:58 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
The vent pipe connects to the filler tube via a small piece of rubber hose at the top, runs down the tube & held in place by the clamps tacked onto the tube. Then exits the trunk floor via a rubber grommet into the frame rail
1MYTGTX
Re: 1970 Charger Refueling Problem [Re: 1MYTGTX] #1026541
07/06/11 10:14 PM
07/06/11 10:14 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
It seems that you guys are forgetting the 1970/71 vent tube. In my 70, there is another pipe just behind the right rear wheelwell inside the trunk. 4 lines go from the gas tank UNDER the car into this tube, with a 5th one that runs out and forward to the engine compartment. This tube in the trunk is the same galvanized type and diameter as the filler tube. I seem to recall that this was an emissions thing that was later changed. I have seen this in A body cars in 1970 and 71 as well.
Re: 1970 Charger Refueling Problem [Re: Kern Dog] #1026542
07/06/11 10:46 PM
07/06/11 10:46 PM
Houston, Tx
Houston, Tx
For '70 Chargers, that's a California thing...........
Troy
Re: 1970 Charger Refueling Problem [Re: Vainglory] #1026543
07/06/11 11:56 PM
07/06/11 11:56 PM
Houston, Tx
Houston, Tx
John.
Here's the tank end of the filler neck.. If something is lodged down there, it'll clog things up for sure.......... It's not a direct filler neck diameter passage as you can see........
Troy
Re: 1970 Charger Refueling Problem [Re: hemi68charger] #1026544
07/07/11 10:31 PM
07/07/11 10:31 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Hmmmmm, Interesting. Thanks.
Learning new stuff is cool!
Re: 1970 Charger Refueling Problem [Re: Kern Dog] #1026545
07/07/11 10:59 PM
07/07/11 10:59 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Need to keep in mind not all gas pumps are equal some times my 67 Belvedere will back gas out because of the pressure of the fuel entering the filler neck. Just a thought from lower Alabama.
Re: 1970 Charger Refueling Problem [Re: Kern Dog] #1026546
07/08/11 09:55 PM
07/08/11 09:55 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
What he said...If you are pumping fuel into your tank and you dont have an exit for the fumes to go through, then you are creating a pressure inside the tank. Similar to a funnel inside a container, when you pour the liquid into the funnel, the vapor cant escape and it causes a pressure bubble to come past the liquid entering, except to a gasoline nozzle it means frequently shutting off. The vent on the filler neck isn't the problem. I have one on my 69 and it does it sometimes. The vent tube is too high up on the filler tube where it wont allow vapor to escape from the fuel tank. My 70 Charger had that vent tube hugging the wheel well on the passnger side. I remember mine having four 3/8" tubes on the tank underneath for emissions and vapor
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
