Re: How much lighter is a 904 than a 4 speed?
[Re: scatpacktom]
#1026476
07/05/11 02:16 PM
07/05/11 02:16 PM
Posts: 20,659 in a cattle trailer down by th...
Guitar Jones
Aluminum, I'm not sure but I can tell you I saved nearly 150 pounds over the cast iron A833 steel bell housing, flywheel and clutch when I installed the 904 with an 8" converter.
[Re: scatpacktom]
#1026477
07/05/11 02:27 PM
07/05/11 02:27 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Just kicking around some ideas. Anybody know the weight difference between a 904 and a alum a833?
So Big Shooter, will we soon be asking you what is the weight difference between a skirt and a pair of pants?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1026479
07/05/11 02:48 PM
07/05/11 02:48 PM
Guitar Jones
Not sure about him but it sure blew my skirt up.
