Re: Bone stock 360 duster runs hot at cruising speeds
[Re: Seth_Jones]
#1026407
07/05/11 12:33 PM
07/05/11 12:33 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Is there a spring in the lower radiator hose? If not it could be collapsing at speed.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: scatpacktom]
#1026409
07/05/11 01:06 PM
07/05/11 01:06 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
I usually block the exhaust crossover in the intake (may not be your problem but it helps) you will then have to richen up the carb.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Savoy1964]
#1026411
07/05/11 02:29 PM
07/05/11 02:29 PM
Posts: 4,322 St. Louis, Mo
318 Stroker
St. Louis, Mo
Had the same problem with my Challenger. A spring cured it...
[Re: dOrk !]
#1026413
07/05/11 03:50 PM
07/05/11 03:50 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Is the radiator used and old? Could be partially clogged and not have enough cooling capacity. At speed the fan is rarely if ever the problem.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1026414
07/05/11 03:53 PM
07/05/11 03:53 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
The fan ? ... you should NOT NEED a fan at 55 mph ...AT ALL.
But the fan-action can be blocking air-flow.
[Re: Paul_Fancsali]
#1026418
07/05/11 04:46 PM
07/05/11 04:46 PM
RapidRobert
Classic partly clogged/too small of rad symptom. Timing in the ballpark at what ever RPM your at at 55 MPH. Stat could b not opening all the way but less likely 2 b it
