Bone stock 360 duster runs hot at cruising speeds #1026406
07/05/11 12:30 PM
07/05/11 12:30 PM
Marion,Indiana
Seth_Jones Offline OP
Marion,Indiana
My just completed 74 360 Duster clone will idle at 190 all day long.Take it down the highway for 10-15 minutes at 55 mph and it creeps up to 220-230. New parts store replacement 26 inch radiator,factory fan shroud,factory aluminum 7 blade clutch fan,stock water pump/pulleys,and 185 thermostat.Any ideas?
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Seth_Jones] #1026407
07/05/11 12:33 PM
07/05/11 12:33 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Is there a spring in the lower radiator hose? If not it could be collapsing at speed.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Savoy1964] #1026408
07/05/11 12:40 PM
07/05/11 12:40 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Get the LM-1 on it Seth. The "tree" in your TQ may not be adjusted properly causing a lean condition. Check the A/F before you pull your hair out
Re: Bone stock 360 duster runs hot at cruising speeds [Re: scatpacktom] #1026409
07/05/11 01:06 PM
07/05/11 01:06 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I usually block the exhaust crossover in the intake (may not be your problem but it helps) you will then have to richen up the carb.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Rapid340] #1026410
07/05/11 02:14 PM
07/05/11 02:14 PM
Marion,Indiana
Marion,Indiana
I can't remember if there is a spring in the lower hose or not,I'll have to check that.
The LM-1 is next on the list Tom,could be way off.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Savoy1964] #1026411
07/05/11 02:29 PM
07/05/11 02:29 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Had the same problem with my Challenger. A spring cured it...
Re: Bone stock 360 duster runs hot at cruising speeds [Re: 318 Stroker] #1026412
07/05/11 03:24 PM
07/05/11 03:24 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Just cruising along at 55 should not collapse the lower hose uNless he has a steep gear in it and the motor is really singing ...IMO.
I would LOOK at that situation ....try it ... but I am thinking the flow through the rad is somehow hindered. Many times I have seen and heard of the fan-action actually blocking air-flow at highway speeds.
Just pull the fan OFF when you take your next HWY-cruise ...and see what happens.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: dOoC] #1026413
07/05/11 03:50 PM
07/05/11 03:50 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Is the radiator used and old? Could be partially clogged and not have enough cooling capacity. At speed the fan is rarely if ever the problem.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Bone stock 360 duster runs hot at cruising speeds [Re: HemiRick] #1026414
07/05/11 03:53 PM
07/05/11 03:53 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
The fan ? ... you should NOT NEED a fan at 55 mph ...AT ALL.
But the fan-action can be blocking air-flow.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Seth_Jones] #1026415
07/05/11 04:00 PM
07/05/11 04:00 PM
P
Paul_Fancsali Offline
P
Change to a 8 blade water pump and put a cavitation disc on the back of the pump blades that should solve the problem. Even the 8 blade will help out esp at speed and lower the anti frez ratio to no more then 30%
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Paul_Fancsali] #1026416
07/05/11 04:43 PM
07/05/11 04:43 PM
Marion,Indiana
Marion,Indiana
3.55 gears turning 2700 rpm.Radiator is new as stated above.Fan is a factory piece.Distilled water with Redline Water Wetter.Did the same thing with anti-freeze too.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Seth_Jones] #1026417
07/05/11 04:45 PM
07/05/11 04:45 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Two EZ things to check ... lower hose and then remove the fan.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Paul_Fancsali] #1026418
07/05/11 04:46 PM
07/05/11 04:46 PM
Classic partly clogged/too small of rad symptom. Timing in the ballpark at what ever RPM your at at 55 MPH. Stat could b not opening all the way but less likely 2 b it
Re: Bone stock 360 duster runs hot at cruising speeds [Re: RapidRobert] #1026419
07/05/11 05:52 PM
07/05/11 05:52 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
mine does this two, around town 180, hyw 200, everything is fine but i have a 6 blade WP that i put in about 10 years ago when i was racing it more often, now that its more of a cruiser i think i need a 8 blade.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Seth_Jones] #1026420
07/05/11 08:04 PM
07/05/11 08:04 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
Was this motor fully rebuilt? Just curious, as the small block is famous for collecting muck around the cylinder walls behind the freeze plugs over time. Had one that overheated like this a while back. Removed all of the freeze plugs on the both sides of the block, cleaned up the muck around the cylinders, replaced the freeze plugs and the motor dropped 20 - 30 degrees in running temperature.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: Seth_Jones] #1026421
07/05/11 11:21 PM
07/05/11 11:21 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...just got back from our local cruise.
..a friend had problems with overheating above 60 mph
..he changed the 7 blade fan for the 5 blade and problem was solved..
as stated it seemed that big 7 blade was blocking air flow at speed.
Re: Bone stock 360 duster runs hot at cruising speeds [Re: can.al] #1026422
07/05/11 11:26 PM
07/05/11 11:26 PM
I had no idea that could happen. Learnt sumpin nu today
