Setting up clutch linkage #1025856
07/04/11 05:21 PM
07/04/11 05:21 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
There is no clutch linkage in my 69 GTX. Engine and transmission are not in the car but I want to install by next week. Does the clutch linkage need to be installed in the car first? Any tips for a smooth install? Thanks
Re: Setting up clutch linkage [Re: frank] #1025857
07/05/11 03:14 PM
07/05/11 03:14 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Much easier to install after the eng/trans have been installed in the car. I always pre-assemble and grease the frame side ball stud in the torque shaft with the seal and clip.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Setting up clutch linkage [Re: frank] #1025858
07/05/11 03:47 PM
07/05/11 03:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Pre-assemble and check everything for straightness and proper rod alignment. Pay special attention to how the rod ends line up with the piviot studs. Correct any misalignment by carefully massaging the parts until you get good straight alignment and flat seating at the pivots. Also, deburr and polish the metal-to-metal contact spots.
I usually find that most of the attachment points on the z-bar to push rod connections out of alignment and they need to be adjusted by slight bending/tweaking to get them to sit flat and have the rods pushing straight.
It makes a huge difference when completely assembled.
Once everything is lined up and seating nicely, I lube all the contact points with that synthetic based, moly, PTFE, graphite impregnated Disc Brake Caliper grease. I like it because it is super slippery, long-lasting and won't attack plastic or rubber parts. It's great lube for so many points on these old cars.
Re: Setting up clutch linkage [Re: jbc426] #1025859
07/05/11 09:27 PM
07/05/11 09:27 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
appreciate your input. Thank you
