replicating cast finish on aluminum #1025684
07/04/11 11:52 AM
07/04/11 11:52 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I bought an Indy intake and compared to Eddy and other castings they look like crap so after grinding off the excess flash and other crud I'd like to replicate the pebbled "cast" finish in those areas. Sandblasting or shot peening hasn't really done it. Anyone got any other ideas?
Re: replicating cast finish on aluminum [Re: Stanton] #1025685
07/04/11 01:49 PM
07/04/11 01:49 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I want to say a member here did just what you're asking about, but I don't recall who it was.
I think a specially ground tip on a punch or chisel was used in combination with a hammer.
Re: replicating cast finish on aluminum [Re: In_The_Pink] #1025686
07/04/11 01:55 PM
07/04/11 01:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Use a needle scaler
Re: replicating cast finish on aluminum [Re: Stanton] #1025687
07/04/11 04:27 PM
07/04/11 04:27 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Like this.....didn't get to the water pump yet.
Re: replicating cast finish on aluminum [Re: ScottSmith_Harms] #1025688
07/04/11 04:29 PM
07/04/11 04:29 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Use a needle scaler
Do you know that this works? I've been thinking of that.
A punch and hammer would take forever!
Re: replicating cast finish on aluminum [Re: Dragula] #1025689
07/04/11 04:31 PM
07/04/11 04:31 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
BEAUTIFUL !!! What did you do that with ??
Re: replicating cast finish on aluminum [Re: Stanton] #1025690
07/04/11 04:32 PM
07/04/11 04:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, works fast and easy, just use a light touch as they can be pretty powerful tools and will dig in deep with aluminum if you allow it. Just practice on some junk parts first to see the results, you can pick one up at Harbor Frieght for about $20.00. They also work well to texture cast iron (to hide welds, etc.)
Re: replicating cast finish on aluminum [Re: ScottSmith_Harms] #1025691
07/04/11 07:41 PM
07/04/11 07:41 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Wow, that's a great tip Scott.. ..Never thought about using one for that purpose...If those pics show the end result I'm definitely giving it a try....
Re: replicating cast finish on aluminum [Re: screamindriver] #1025692
07/04/11 07:50 PM
07/04/11 07:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Timely post: I want to remove some Edelbrock lettering from an intake.
What the heck does a needle scaler look like?
Re: replicating cast finish on aluminum [Re: topside] #1025693
07/04/11 08:05 PM
07/04/11 08:05 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Re: replicating cast finish on aluminum [Re: topside] #1025694
07/04/11 08:25 PM
07/04/11 08:25 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
file that off, or use a dremel with a roll sand paper grinder on it, then add the texture to it.
Re: replicating cast finish on aluminum [Re: Stanton] #1025695
07/04/11 11:54 PM
07/04/11 11:54 PM
Dragula Offline
Dragula  Offline
I started by grinding off all the logo and part numbers and anything that was on the intake I was never going to use. The glass beaded it at 70psi, primered it with Walmart grey primer was $1.98/can and then used a light misting of Mopar Argent Silver wheel paint $10/can. Comes out just like cast aluminum that was just cleaned. Holds up to fuel and oil pretty well too. You can see where I taped off the master cylinder and got a little over spray on it.
