Under hood fuse block on classic mopar?
#1025613
07/04/11 02:54 AM
07/04/11 02:54 AM
Posts: 363 kentucky
roadrunner7020
kentucky
I am throwing around the idea of making multiple relay harnesses for both my 1970 roadrunner as well as my 1972 Challenger, I know as a general rule when running relay harnesses for things such as headlights or fuel pumps it is recommended to run a fuse between the battery and the relay on a 12v circuit. In order to get a cleaner look I debated on purchasing an aftermarket fuse block or even an modern OEM fuse block to wire each connection through. Could a buy a factory underhood fusebox mount it my car have all fuses wired to a constant 12v from the battery and then make each fuse outlet be the fused 12v link to each of my Relay Harnesses? I like the idea of something like Fuse block 1 or Fuse box 2. I would prefer to be able to run one 12v source for everything instead of each individual fuse if possible. I plan on having many add on accessories such as H4 headlights possibly HID, electric fuel pumps, electric fans, aftermarket gauges and ignition among a few other things. Just looking to see if my idea would be possible before I start rounding up supplies for my project. Thanks in advance everyone
Re: Under hood fuse block on classic mopar?
[Re: roadrunner7020]
#1025614
07/04/11 03:20 AM
07/04/11 03:20 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Overall a good plan but I believe with a little more searching you'll find a combo fuse box/relay box which would really clean things up...
[Re: Jim_Lusk]
#1025616
07/04/11 07:28 AM
07/04/11 07:28 AM
Posts: 416 Franklin Co. Illinois
runinonmt
If I ever have to rewire my Duster I'll use the box from a Dakota. Take a look under the hood and you'll see they're set up quite similar to our old Mopars. Grab as much wiring as you can. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
#1025619
07/05/11 02:13 PM
07/05/11 02:13 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
Thanks for the help everyone I am not completely residing the cars but rather adding an extension harness I suppose you'd say using the old wiring as trigger wires to signal the new higher current accessories.
Thats exactly what I did. I used the underhood relay box out of a 97 Intrepid and ran a hot wire from the alt to the fuse box. I use 4 relays and fuses and have room for more if needed. Nice part is that from the junkyard the box comes complete with fuses and relays.
[Re: Jim_Lusk]
#1025622
07/05/11 04:25 PM
07/05/11 04:25 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
A lot of modern cars have those under the hood. A stroll through the self serve wrecking yards around here has shown all sorts of relay/fuse boxes of all sizes. Make your plan first and go hunting.
You're more likely to find what you really need at the pick-n-pull.
I used a fusible link box from a mid 80's Maxima for feed to headlight box, rad fan, dash power (back through the bulkhead), and battery charge wire (trunk mount battery).
Then used a headlight relay box from a Tercel to relay-up and fuse the headlights.
The fusible link box is about the size of a cigarette pack and mounted on firewall behind passenger valve cover so a short supply run from the alternator.
The headlight relay box is on fender right behind driver's headlight buckets. Relays and fuses supply H4/H1 headlights. Pic is of headlight relay box.
#1025623
07/07/11 02:03 PM
07/07/11 02:03 PM
GTXKen
super gas
super gas
Thanks again. GTXKEN is that all you need to run is a positive from the alternator to the fuse box and I assume a chassis ground then wire it as you'd like? Does anyone know what cars use Bosch style relays? That all I really know how to use I am not opposed to learning something new but if possible of like to stock to what I know. Also with my car having the battery up front any mounting ideas?
You need to do is power the bus bar inside this box, that can come from a battery, starter relay or in my case the alternator, my battery is in the trunk and my relay is under the dash. Then from the dash switch to the relay and from the relay to the lights or whatever you are powering. These are bosch style relays. I'd mount the fuse/relay box next to or under the battery tray. You could make an L shaped bracket and attach it to the battery tray. Thats how many late models are.
