Re: very thin steel headgasket
[Re: moparmikethree]
#1025496
07/04/11 02:37 AM
07/04/11 02:37 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
Instead of sinking money into the open chamber heads, you may want to spring now for an upgrade to Magnum heads. The Magnum heads flow much better, and the closed chamber design will pick you up about a 1/2 point or so of compression (maybe a little more on a 318).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
#1025497
07/04/11 03:49 AM
07/04/11 03:49 AM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
Was another post on here or on FABO, about thin steel gaskets. You can search this number and bring up the posts I think.
Head gasket P4286754 steel shim 0.020" thick At dealer have them use Chrysler Dealer Connect for search Also, can try Pt#3614824 (at parts store?)
A True Hybrid: Burns Gas AND Rubber!
#1025498
07/04/11 08:27 AM
07/04/11 08:27 AM
Posts: 159 Woodward, PA
75DART440
Woodward, PA
Another possibility for a healthy bump in compression would be the 87-91 closed chamber heads. Last three digits of the casting number are 302. While not as good as the magnum heads, they require no other parts swapping and should be available at a salvage yard near you.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!!
Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
[Re: MoparforLife]
#1025504
07/04/11 02:03 PM
07/04/11 02:03 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
bought 3 sets a few months ago from them...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
