very thin steel headgasket #1025494
07/04/11 12:41 AM
07/04/11 12:41 AM
Harrisburg Pa. 17112
moparmikethree Offline OP
Back in the early 80's , I remember on the 318's had a
very thin, single layer steel headgasket. does anyone know where to get them now? i want to try to raise the compression ratio, the slugs are .070 in the hole. i'll also have the heads milled
Re: very thin steel headgasket [Re: moparmikethree] #1025495
07/04/11 01:03 AM
07/04/11 01:03 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
mopar P4120094 .024-.028
Tony
70 AARCuda Vitamin C
Re: very thin steel headgasket [Re: moparmikethree] #1025496
07/04/11 02:37 AM
07/04/11 02:37 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Instead of sinking money into the open chamber heads, you may want to spring now for an upgrade to Magnum heads. The Magnum heads flow much better, and the closed chamber design will pick you up about a 1/2 point or so of compression (maybe a little more on a 318).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: very thin steel headgasket [Re: moparmikethree] #1025497
07/04/11 03:49 AM
07/04/11 03:49 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
Was another post on here or on FABO, about thin steel gaskets. You can search this number and bring up the posts I think.
Head gasket P4286754
steel shim 0.020" thick
At dealer have them use Chrysler Dealer Connect for search
Also, can try Pt#3614824 (at parts store?)
A True Hybrid: Burns Gas AND Rubber!
Re: very thin steel headgasket [Re: moparmikethree] #1025498
07/04/11 08:27 AM
07/04/11 08:27 AM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
Another possibility for a healthy bump in compression would be the 87-91 closed chamber heads. Last three digits of the casting number are 302. While not as good as the magnum heads, they require no other parts swapping and should be available at a salvage yard near you.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: very thin steel headgasket [Re: 70AARcuda] #1025499
07/04/11 09:58 AM
07/04/11 09:58 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
are a thin composite gasket.
Re: very thin steel headgasket [Re: moparmikethree] #1025500
07/04/11 10:46 AM
07/04/11 10:46 AM
IMGTX Offline
IMGTX  Offline
PAW used to sell them in their rebuild gasket kits.
You could buy 2 full gasket kits for the price of one pair of mopar head gaskets. They went out of business but I would like to find their old supplier.
Re: very thin steel headgasket [Re: IMGTX] #1025501
07/04/11 11:15 AM
07/04/11 11:15 AM
florida
74fldart Offline
74fldart  Offline
florida
summitt racing was carrying them a yr or so ago.
Re: very thin steel headgasket [Re: MoparforLife] #1025502
07/04/11 11:20 AM
07/04/11 11:20 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes they are...
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=247
Tony
Re: very thin steel headgasket [Re: 70AARcuda] #1025503
07/04/11 01:28 PM
07/04/11 01:28 PM
Upper Midwest
Upper Midwest
Everybody was out of stock a year or so ago. I sold one of my spare sets then.
Re: very thin steel headgasket [Re: MoparforLife] #1025504
07/04/11 02:03 PM
07/04/11 02:03 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
bought 3 sets a few months ago from them...
Tony
Re: very thin steel headgasket [Re: 70AARcuda] #1025505
07/04/11 05:53 PM
07/04/11 05:53 PM
I have a set of Magnum heads, I'm going to use.
In addition to the thin gaskets
