RHS heads and manifolds #1025344
07/03/11 09:47 PM
07/03/11 09:47 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Anyone running a set of RHS heads with factory 340 exhaust manifolds ? I know there were issues with running them on Magnum heads
Re: RHS heads and manifolds [Re: AdamR] #1025345
07/04/11 02:46 AM
07/04/11 02:46 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I'm running early 340 manifolds on factory Magnum heads. Some guys have had trouble with a bump on the Magnum heads that would prevent the manifold from bolting down flush.
To me, the bigger problem is the floor of the Magnum exhaust port is raised significantly to improve on the flow. This leaves only about 1/8" of common gasket sealing surface between the LA and Mag ports. Remflex gaskets solved my leaks.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: RHS heads and manifolds [Re: GO_Fish] #1025346
07/05/11 08:01 PM
07/05/11 08:01 PM
Bethel Ct
AdamR Offline OP
AdamR  Offline OP
Bethel Ct
Is this your motor ?
Re: RHS heads and manifolds [Re: AdamR] #1025347
07/05/11 08:44 PM
07/05/11 08:44 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
No, but that is a great shot that shows the mismatch at the bottom of the exhaust ports.
I made some sheet metal adapters, outside dimensions traced off an LA port, inside dimensions traced off the Magnum port. I'm not sure if they helped or not. The driver side sealed properly with my adapters and parts store gasket, but the passenger side needed a Remflex gasket to seal.
