Carb for 66 273 cuda #102519
08/10/08 06:19 PM
08/10/08 06:19 PM
California
Drip Offline OP
Drip  Offline OP
California
i need to buy a new carb for my 273 and was wondering what i should get. it is a 273 comando motor with an auto. The motor is stock.
thanks
Re: Carb for 66 273 cuda [Re: Drip] #102520
08/10/08 06:56 PM
08/10/08 06:56 PM
the original would have been an AFB so if keeping ths same intake you'd need a small a 4bbl as possible 500-600 cfm with the AFB bolt pattern. As far as what is available now someone else will address that.
Re: Carb for 66 273 cuda [Re: Drip] #102521
08/11/08 09:40 AM
08/11/08 09:40 AM
Marietta, GA
Joatha Offline
Joatha  Offline
Marietta, GA
Nevermind...I can't read apparently.
1966 Barracuda 1968 Barracuda convertible 1930 Ford Model A (soon to be hemi equipped) 2006 Dodge 3500 4X4 CTD Quad Cab
Re: Carb for 66 273 cuda [Re: Joatha] #102522
08/11/08 10:41 AM
08/11/08 10:41 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The problem with any aftermarket carb is that your air cleaner won't fit anymore. There are rebuild services for the original carbs that will fix sloppiness in the throttle shafts and any other wear issues.
