What tach works best with Pertronix setup? #1025101
07/03/11 12:15 PM
07/03/11 12:15 PM
OK
David_Trimble Offline OP
OK
I've got a '69 Charger R/T currently with a 383 and Pertronix setup. Now I've got 2 'old school' tune-up point/dwell/tach analyzers (one's from the '70s the other the '80s) and neither of them apparently are compatible with the Pertronix, as when I hook them up to the coil I get NO RPM readings.
What brand(s) tune-up tachs out there are compatible with a Pertronix system?
Thanks!
David
'69 Dodge Charger R/T
Re: What tach works best with Pertronix setup? [Re: David_Trimble] #1025102
07/03/11 01:35 PM
07/03/11 01:35 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
connect it to the other side of the coil
i have no problems with any tach with my pertronix stuff
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: What tach works best with Pertronix setup? [Re: amxautox] #1025103
07/03/11 01:39 PM
07/03/11 01:39 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
I thought about asking if it were wired correctly but thought could not be the problem.
Re: What tach works best with Pertronix setup? [Re: TheBlueBeast] #1025104
07/03/11 01:51 PM
07/03/11 01:51 PM
amxautox Offline
amxautox  Offline
i've done it, so it's on my minds most times when I connect a tach.
Tom
author unknown
Re: What tach works best with Pertronix setup? [Re: amxautox] #1025105
07/03/11 01:59 PM
07/03/11 01:59 PM
OK
OK
Ok, so in other words noone's had trouble with even a old dwell/tach/point meter working with Pertronix? I'll doublecheck the wiring. I'll also try out the meters on another car- it's possible I suppose that the meters have gone kaput...
Re: What tach works best with Pertronix setup? [Re: David_Trimble] #1025106
07/04/11 09:56 AM
07/04/11 09:56 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
- side of coil?
Re: What tach works best with Pertronix setup? [Re: meepmeep70] #1025107
07/04/11 11:30 AM
07/04/11 11:30 AM
OK
OK
Actually it turned out that one of my meters had died The other one - and yes when I swapped it to the other coil connection - worked just fine. So we're good- thanks all for the help!
David
