Holley 750 Questions #1024950
07/03/11 01:03 AM
07/03/11 01:03 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I am trying to put a 750 vacuum secondary (3310) carb together for my relatively stock (aftermarket intake - - not sure on the cam) 383 67 Coronet. I was going to go with a 650, but can't get the linkage geometry correct.
Questions about the 750:
- I have (2) 3310 carbs - one with metering block and one with a metering plate. Can I swap the block with the plate? I may have drilled out the plate holes when I was young and stupid. The carb with a metering plate is overall in much better shape.
- What size jets do I start with? What would it have come with originally (using the metering block for the secondary).
- Being relatively stock, what size power valve should I start with?
Re: Holley 750 Questions [Re: markz528] #1024951
07/03/11 01:10 AM
07/03/11 01:10 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I think it's something like 72/81 and 6.5/plug on the PVs
Re: Holley 750 Questions [Re: markz528] #1024952
07/03/11 01:11 AM
07/03/11 01:11 AM
(1) yes swap it & get a longer chromed dual feed line or cut your current one & add a piece of neoprene hose (looks unsightly but works) (2) not sure on jet size (3) Start w 1/2 of your manifold vacuum amt at idle in gear (auto) w foot on brake or e brake set (neutral if stick).
Re: Holley 750 Questions [Re: RapidRobert] #1024953
07/03/11 01:34 AM
07/03/11 01:34 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
holley carbs need holley PN 20-7 to get linkage correct.
Tony
70 AARCuda Vitamin C
Re: Holley 750 Questions [Re: 70AARcuda] #1024954
07/03/11 01:43 AM
07/03/11 01:43 AM
Ding Ding Ding I do believe we have a winna. That bent bracket is cheap too & an o'reilly's that has a carb accessories section will have it
Re: Holley 750 Questions [Re: 70AARcuda] #1024955
07/03/11 11:02 AM
07/03/11 11:02 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
That's what I use...........
Re: Holley 750 Questions [Re: markz528] #1024956
07/03/11 01:04 PM
07/03/11 01:04 PM
What is binding up/wrong angle? From the side view what is diff between the 2 carbs' throttle bracket assy's w the 20-7 bolted on either one
Re: Holley 750 Questions [Re: RapidRobert] #1024957
07/03/11 01:16 PM
07/03/11 01:16 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
The 650 is a spread bore and was OEM on a GM application. The 20-7 bracket bolts up (with a very minor tweak to one of the holes) but the effective radius is wrong. It only opens about 70% and then runs out of throttle cable length.
Re: Holley 750 Questions [Re: markz528] #1024958
07/03/11 01:30 PM
07/03/11 01:30 PM
Locomotion Offline
Locomotion  Offline
When converting from the OEM secondary plate to a metering block, the correct jet size will be 75 or 76. I forgot which one, but Holley has a reference chart showing the corresponding jet size for several of their plates.
If the metering block in one of the 3310's is original, then that is the first model of the 3310 and was rated at 780 (3310 or 3310-1). Original jets would have been 76. After they went to the plate for the secondaries, it was re-rated at 750. Don't know off hand what caused the reduced flow, but it's nothing to worry about.
Re: Holley 750 Questions [Re: Locomotion] #1024959
07/03/11 01:39 PM
07/03/11 01:39 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Actually both are 3310-2. I bought the second carb cheap primarily for parts including the metering block.
I guess someone must have added the block at some point.
The carb that had the block in it had 72 in the front and 79 in the back. I'm kinda leaning towards keeping it fat and staying with the 79's till I can tune it.
