Page 3 of 3 1 2 3
Re: Tranny Explodes [Re: maximum entropy] #1024699
07/03/11 09:21 PM
07/03/11 09:21 PM
PA
moparacer Offline
moparacer  Offline
PA
If you are making ANY amount of serious power JUST PUT A GLIDE IN IT....
Nuff said....
I might be a mopar guy at heart but I do happen to value walking around with both feet properly attached thank you.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Tranny Explodes [Re: moparacer] #1024700
07/03/11 10:18 PM
07/03/11 10:18 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
But NO ... you are not ..... you are deep-down a GovernmentMotors ..... ...
Yes ...feet are important part of the body ...and YES ... 727's BLOW UP .....
But if you have the proper parts IN THE TRANS .. they are as "safe" as any 727 in a daily-driver.
Re: Tranny Explodes [Re: 1_WILD_RT] #1024701
07/03/11 10:43 PM
07/03/11 10:43 PM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
But the cause is letting off the throttle in 1st gear with no low band (rear band) apply in 1st gear.
So your saying the direct(front) drum is being spun to burst speed when you lift throttle in first gear and the roller clutch freewheels?
I really think you are misinforming people with this statement.
Hutch
No! That is not what he is saying... The explosion occurs when you launch after having let off the throttle at high RPM with the shifter in first gear with no low band apply.... This can allow the sprag to lay over... Once the sprag lays over the pin has been pulled.. If you miss the signs an explosion is eminent... A bolt in sprag does nothing to stop the problem because all a bolt in sprag does is secure the outer portion of the sprag to the trans case with bolts rather than splines & a set screw... A low band apply valve body prevents the issue by holding the low/reverse drum so the sprag doesn't see the load that could cause it to fail... An aluminum or billet drum doesn't prevent the sprag failure but the drum is of higher quality & if the sprag does fail the drum doesn't fail so theres no explosion.. What is being pointed out is if your aware of the problem, know the cause & drive with the proper procedure than there is no problem... Either start the burnout in second or shift to second before getting out of the gas..... Also be out of first before the tires hit dry pavement.. The shock of the tires grabbing coming out of the burnout box can shock the sprag causing it to lay over.... Be aware...... Or don't pay attention & just buy a low band apply valve body so your protected....
I am very aware of WHY they blow up that is why I made a comment about the statement I quoted prior to yours which states the "cause" which is inaccurate and misinformative IMO. Im not looking to get into it , just to offer proper accurate info. Lifting off the throttle w/o low band apply does nothing to the roller clutch. Improper burnout procedure , jackstand transbrake tests , improper assembly of roller clutch (roller diameter or spring direction/condition) inner race preparation and the list goes on is the cause of the problem. Low band apply helps stabilize the clutch but is not the cure.
Hutch
Re: Tranny Explodes [Re: terzmo] #1024702
07/03/11 11:48 PM
07/03/11 11:48 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Sorry to hear about that. mine let go at the other end (116mph). U-joint puked a cap and the vibration trashed the trans. Parts were everywhere.
Good luck bro.
Coming soon!!!!
Re: Tranny Explodes [Re: Mr.Yuck] #1024703
07/04/11 01:45 AM
07/04/11 01:45 AM
michigan
6pakdakota Offline
6pakdakota  Offline
michigan
i have a used manual valve body 727 that i am getting ready to put in my truck. how can i tell if it is a low band apply valve body or if it is already damaged or not?
Re: Tranny Explodes [Re: dOc !] #1024704
07/04/11 08:49 AM
07/04/11 08:49 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Are the tranzact transbrake LBA or is it different with a transbrake?
Re: Tranny Explodes [Re: Hutch] #1024705
07/04/11 08:54 AM
07/04/11 08:54 AM
NC
440Jim Offline
440Jim  Offline
NC
Hutch
I am not trying to misinform people, you don't understand. You are the one that posted the burst speed statement, not me. I was commenting on driving technique.
It is the unloading and reloading the sprag that can damage it. It all started (in this case) with lifting in 1st gear with no low band apply. That in itself may not roll the sprag, but if the driver shifts to 2nd before lifting, the reloading of the sprag will never happen and therefore avoid damage.
Only after the sprag is rolled, and the trans is in 1st gear with no low band apply and power is applied; then the front drum spins at 2.2 engine speed. This could happen on the next launch, when the damage was done in the previous launch.
The point I was trying to make, without the long and confusing explaination, is to shift to 2nd when something goes wrong. If you need to lift the throttle for other safety reasons, still shift to 2nd!
Re: Tranny Explodes [Re: rapom] #1024706
07/04/11 11:58 AM
07/04/11 11:58 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Doing a burn out in 1st. gear. I'll let others explain.
This was on launch..not burnout
Re: Tranny Explodes [Re: MR_P_BODY] #1024707
07/04/11 11:59 AM
07/04/11 11:59 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Just what Mr. P body says.
GET A BLANKET OR A SHIELD!!!!!
Wait a second. How does a 4-link car with a funny car tire SPIN...??
Simple... pump them up like a basket ball
tire pressure was no over inflated
Re: Tranny Explodes [Re: terzmo] #1024708
07/04/11 12:44 PM
07/04/11 12:44 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
But did he do the burn out in 1st gear ?
Re: Tranny Explodes [Re: terzmo] #1024709
07/04/11 01:34 PM
07/04/11 01:34 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
From what I have heard(never seen this happen) ... is that you can damage the sprag on a burnout(when coming out of the water by hooking then spinning then hooking again).....THEN on the launch the sprag comes apart and the insides spin 2.5 times engine speed.
WITH an alum drum(or billet steel) ... no V8 Mopsar engine is capable of reving HIGH ENOUGH to explode the front-drum.
Re: Tranny Explodes [Re: VernMotor] #1024710
07/04/11 03:18 PM
07/04/11 03:18 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
no..2nd
Re: Tranny Explodes [Re: terzmo] #1024711
07/04/11 04:09 PM
07/04/11 04:09 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You guys are making way too much out of an improper burn out and the reflex to lift when it spun at the hit.
Turns out we could not get a LBA VB as too many don't like the drag they produce, so it will be the standard one....
Re: Tranny Explodes [Re: 440Jim] #1024712
07/04/11 08:38 PM
07/04/11 08:38 PM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
Hutch
Once again , your confusing people. You stated ,when you get into trouble on the track we should now shift to 2nd and that will prevent future roller clutch failures? HELL NO!!
If we lift throttle in low gear and do not shift to 2nd we will kill the roller clutch? HELL NO!!!
Pedalling the car in low gear can damage a roller clutch. HELL YES!!
Just wanting to clarify this with you.
Hutch
Re: Tranny Explodes [Re: Hutch] #1024713
07/04/11 10:33 PM
07/04/11 10:33 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I have had 2 bad breaks with my 727 in my car. Both in 1st gear, both under serious power (25-30lbs of boost)
One pass I broke an axle, motor went to the moon, next year broke something inside the trans, motor went to the moon (9500rpm)
What I can say is that I run a low band apply vb with billet steel drup and a super sprag and never had a serious issue like the op did.
I will say though for me all I could do was call hutch and get some info in where to get a bullet proof turbo 400 and he did just that (proformance in chicago) as I am sick of breaking parts
Page 3 of 3 1 2 3
