Page 2 of 3 1 2 3
Re: Tranny Explodes [Re: MR_P_BODY] #1024679
07/02/11 11:22 PM
07/02/11 11:22 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
To answer the OP - The drum exploded, you had the stock cast iron drum in there and you need to call John Cope and get a billet or aluminum drum in your next tranny.
The super sprag or at least a bolt in unit will prevent things from going bad as well, but the drum is what exploded.
I still run a stock drum... its what you do and dont do
that keeps it from blowing... and a bolt in sprag
wont save anything... if you want a good sprag you
better be looking at a super sprag or the like
Dont get me wrong - some people - make that alot of people do it - does it make it right? if doing something unsafe and getting away with it makes it right? nope!
The bottom line is there is a bomb in every single stock drum 727 out there. the part that explodes is the drum, you can dance with the devil your whole life and win, or tomorrow might be your time -
WHY RISK IT?
It could go through your body and kill you... is that really worth it?
just to say you can do it?
Re: Tranny Explodes [Re: DJVCuda] #1024680
07/02/11 11:29 PM
07/02/11 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
WHY RISK IT?
Dont do STUPID SH***T... and 1 is letting off the
pedal in low gear at high RPM... I believe its 13.5K
for that stock drum to over rev and blow
EDIT
and when you let off at high evs it blows the sprag
and then it turns 2.2 times the engine
Re: Tranny Explodes [Re: MR_P_BODY] #1024681
07/02/11 11:44 PM
07/02/11 11:44 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
"Dont do STUPID SH***T... and 1 is letting off the
EDIT
and then it turns 2.2 times the engine"
That pretty much sums it up.
If a drum blows, it is because on either that run, or shortly before, someone did something dumb or made a mistake and never checked it. The sprag doesn't turn by itself. DJV, To insunuate that us old timers who have been using pretty much stock Torqueflites since Moby Dick was a minnow are either too stupid to know better or are spitting in the eye of the reaper is insulting. We just take issue with your statement. I'm pretty sure that I speak for all of us when I tell you that if we were convinced that it was an overly unnecessary risk, no one would take it. But, to my mind, it is low on the list of things that could happen, if one is careful and pays attention to what they are doing. Do I use a blanket? Of course, that is the smart thing to do. My belts are also up to date, and my suit and helmet meet specs. My brakes also work.
I've been doing this since 1964, and have only seen one explode, and it was preventable. This, of course, is not including the neutral start craze of 67-68, which is another story altogether. That was before the advent of high stall converters, and Chrysler itself was involved with that. Dave Wren "invented" it at the Chrysler proving ground, and everyone was doing it. The famous pic, earlier in this post, was of Dick Oldfield's Iron Butterfly 64 Hemi at Indy while the neutral start deal was in vogue. Ron Mancini had a big one at Bristol earlier that year, and NHRA stopped it after Dick's deal. Whoever posted that pic should have been more specific....that is famous pic that has appeared about everywhere. One needs to tell the whole story, providing they know it. Otherwise, hysterical threads like this have every eighteen year old kid who races a 318 Duster out buying $700 drums that they really can't afford because "every 727 has a bomb in it". Gimme a break.....big time overstatement.
Re: Tranny Explodes [Re: Steve1118] #1024682
07/03/11 12:59 AM
07/03/11 12:59 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Ok 1964 was a long time ago, so vs any of the older crowd getting bent lets just flip it around and blame these two recent exp. 727s on the ignorance of the youth of today.
With that the fact remains just this week there has been two blow and one guy hurt, I myself have never had an oem 727 come apart, however even in my street beater spray car I run a crt pro race as well with the blanket because I do value my feet and my passenger.
So really at the end of the day does it matter how old one is in this whole big picture, 727-s blowup.
What im really surprised about is the moral police on moparts should be all over this one but I guess as long as its not there foot busted up its ok.
Do I really care if one gets there foot blown off, young or old, not really its just silly to see it happen, when things can be done to prevent it or reduce the chance of driver harm.
Ive noticed that many who have not replied to this are the people running the right drums and shields or blankets as required by tech, and now dam, what am I to do with a guy like John Cope selling me a perfect working trans that I have zero worries with except say THANKS!
Re: Tranny Explodes [Re: Steve1118] #1024683
07/03/11 01:01 AM
07/03/11 01:01 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ran the stock/lightened one on the right for 15 years or so. Early Tranz Act NON reverse band apply t-brake (still in the car). I started having some psi issues and had the trans freshened and went with a billet front drum. I asked about upgrading the rear roller assy and the builder said mine was fine and that he wouldn't spend the money unless the race was worn or loose.
Re: Tranny Explodes [Re: J_BODY] #1024684
07/03/11 01:03 AM
07/03/11 01:03 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...and been running this since....well a long time!
Re: Tranny Explodes [Re: terzmo] #1024685
07/03/11 01:08 AM
07/03/11 01:08 AM
NC
440Jim Offline
440Jim  Offline
NC
Sorry to hear about that disaster.
An aluminum front drum would have prevented the major damage.
But the cause is letting off the throttle in 1st gear with no low band (rear band) apply in 1st gear. Some valve bodies have it, some don't. The best thing to do in a TF trans is shift to 2nd when that happens, not just lift.
Re: Tranny Explodes [Re: J_BODY] #1024686
07/03/11 01:08 AM
07/03/11 01:08 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
This one had the engine set back about 10 inches. Rear gear broke on the launch, folded the springs in the roller with the shock, and the rest made a mess.....and he walked away!!! Pieces of trans stuck in his door panel, dent in the roof, and a chunk of drum wiped out the gauges if I recall. This was long before Al Gore invented the interwebs so we hadn't ever seen/heard anything like it. But we learned!
Re: Tranny Explodes [Re: quick77rt ] #1024687
07/03/11 01:10 AM
07/03/11 01:10 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have one on the floor that's ready to blow up right now. It whines and rattles and starts humming like it is just waiting to blow.
It was in the valiant when the rear end let go lol So now im building a new tranny with an alum drum and a pro tree break.
Can't wait to be able to trans break it every pass.
Re: Tranny Explodes [Re: FastmOp] #1024688
07/03/11 01:28 AM
07/03/11 01:28 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
You can put a CAST IRON shield around it... with two blankets. THAT might prevent the floor from being damaged ... but how about the converter, the case, valve body and everything else ? ...
Could be JUNK if all that happened.
A billet steel drum is good ... but a steel-jacketed alum drum is the ticket. The 727 can NEVER "blow-up".
Re: Tranny Explodes [Re: J_BODY] #1024689
07/03/11 01:38 AM
07/03/11 01:38 AM
So if I'm running the 17156 manual valvebody (no low band apply) that Turbo Action sells, I shouldn't let off the gas in first gear crusing down the street?
I'm aware of the no first gear burnout deal.
Re: Tranny Explodes #1024690
07/03/11 01:41 AM
07/03/11 01:41 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I think that`s the one I have and I never get on and off the gas in first ANYWHERE. Sometimes on the street I even take off in second and cruise parking lots in second also.
Re: Tranny Explodes [Re: 440Jim] #1024691
07/03/11 01:57 AM
07/03/11 01:57 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
So your saying the direct(front) drum is being spun to burst speed when you lift throttle in first gear and the roller clutch freewheels?
I really think you are misinforming people with this statement.
Hutch
Re: Tranny Explodes [Re: Hutch] #1024692
07/03/11 02:20 AM
07/03/11 02:20 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I have had 2 different sprag failures on my 904 without blowing the front drum(stock), both times I caught it early on launch as it acted just like the tires were spinning and never got the Engine Rpm up high enough to cause burst damage. I think many people mistake wheel spin for sprag failure to begin with. Glad your buddy hobbled away from this one. Hope he feels better soon.
Re: Tranny Explodes [Re: wheelsup68dart] #1024693
07/03/11 02:57 AM
07/03/11 02:57 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
904 drum has less mass than a 727. When I was talking to Dave Smith on this subject he said he'd never seen a 904 drum come apart.
Re: Tranny Explodes [Re: Hutch] #1024694
07/03/11 03:53 AM
07/03/11 03:53 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hutch
No! That is not what he is saying... The explosion occurs when you launch after having let off the throttle at high RPM with the shifter in first gear with no low band apply.... This can allow the sprag to lay over... Once the sprag lays over the pin has been pulled.. If you miss the signs an explosion is eminent... A bolt in sprag does nothing to stop the problem because all a bolt in sprag does is secure the outer portion of the sprag to the trans case with bolts rather than splines & a set screw... A low band apply valve body prevents the issue by holding the low/reverse drum so the sprag doesn't see the load that could cause it to fail... An aluminum or billet drum doesn't prevent the sprag failure but the drum is of higher quality & if the sprag does fail the drum doesn't fail so theres no explosion.. What is being pointed out is if your aware of the problem, know the cause & drive with the proper procedure than there is no problem... Either start the burnout in second or shift to second before getting out of the gas..... Also be out of first before the tires hit dry pavement.. The shock of the tires grabbing coming out of the burnout box can shock the sprag causing it to lay over.... Be aware...... Or don't pay attention & just buy a low band apply valve body so your protected....
Re: Tranny Explodes [Re: 1_WILD_RT] #1024695
07/03/11 07:51 AM
07/03/11 07:51 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Could loosing traction at the line roll the sprag?
Is there any signs that the sprag is shot before you start running the car?
Re: Tranny Explodes [Re: J_BODY] #1024696
07/03/11 12:36 PM
07/03/11 12:36 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
What was the gauge/thickness of that modified trans tunnel?
Whoever drove that car was VERY lucky that day!!
A lot of racers complain about safety rules...They are trying to make our sport safer.
If your foot or hand gets broken/mangled and you can't work, now what?
I ran with a stock drum for a long time.
When it was being freshened we would look for cracks, and replace.
I ALWAYS start my burnout in 2nd gear.
I also had a trans shield and flexplate shield per NHRA rules. Just to be safe.
Never tested the shields, thank GOD.
Don
Re: Tranny Explodes [Re: MR_P_BODY] #1024697
07/03/11 04:08 PM
07/03/11 04:08 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
727 6-Bolt Ultimate Sprag (1966-1989) - A&A Transmissions good bolt in spaq is 200 bucks here from a+a i dont build mine with out it. they dont blow up
MOPAR OR NO CAR
Re: Tranny Explodes [Re: hemigod426] #1024698
07/03/11 07:02 PM
07/03/11 07:02 PM
organ
maximum entropy Offline
organ
they'll often fill the car with fire as an added bonus. super sprag, billet drum, blanket or shield, and a low band apply valve body, and he'd still be racing. my street car has all of the above and more. i like spending money on things that make my car more reliable at high performance levels. i hate fire and shrapnel in the car. it takes the joy right out of it.
Page 2 of 3 1 2 3
