1st time at the dragstrip - help me estimate my hp? #1023929
07/01/11 01:13 PM
07/01/11 01:13 PM
leawood, ks
johnv Offline OP
johnv  Offline OP
leawood, ks
So, I took my car to the strip for the 1st time. It has a fresh 505 big block that was dyno’ed at 536 hp, 5400 rpm (flywheel hp, open headers). I am trying to estimate how “happy” the dyno was:
The car:
1969 road runner
fiberglass hood
no front bumper
aluminum heads, intake, master cylinder
about 30 lbs of hushmat
about 30 lbs of torque boxes, frame connectors
I would guess 3800 lbs with driver
3.23 no sure grip
4 speed
power steering
normal 7 blade fan, no clutch
headers but otherwise full exhaust
Weather was hot, maybe 85F, 60% RH
My runs:
13.46 @103.3 - 2.31 60’ - missed 3rd and shut down a little early
14.38 @108.4 – 2.91 60’ – spun badly off the line
13.52 @109.9 – 2.47 60’ – no major incidents
I was out launched badly every time, probably because of driver and traction issues.
Thanks!
Re: 1st time at the dragstrip - help me estimate my hp? [Re: johnv] #1023930
07/01/11 01:41 PM
07/01/11 01:41 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I estimated 3850 w/ driver, since I actually think people underestimate their weights/fuel/etc....
BUT, given you're trap speeds, I'd say right around 400hp to the rear wheels.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: 1st time at the dragstrip - help me estimate my hp? [Re: johnv] #1023931
07/01/11 05:52 PM
07/01/11 05:52 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Broken parts are probably in your future, especially if you put slicks on. 505 + 4 speed + open diff
Re: 1st time at the dragstrip - help me estimate my hp? [Re: johnv] #1023932
07/01/11 06:02 PM
07/01/11 06:02 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I'm guessing your race weight at closer to 3900. Based on your MPH you should be at 394 at the rearwheels.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 1st time at the dragstrip - help me estimate my hp? [Re: johnv] #1023933
07/02/11 02:32 PM
07/02/11 02:32 PM
leawood, ks
johnv Offline OP
johnv  Offline OP
leawood, ks
Well, when I used the calculator, I got 393 rwhp. However, plugging that into the et calculator gives 12.4 ET (vs 13.5 that it ran). So I obviously am not getting all of the power to the ground.
Assuming I somehow got it to run 12.4, I would have to think my trap speed would go up maybe 2-3 mph, so more hp by the calculator.
I think that maybe the final number would settle in around low to mid 400's after iterating between the ET and trap speed calculators, which isn't far from what the dyno got.
Or am I in denial??
Re: 1st time at the dragstrip - help me estimate my hp? [Re: johnv] #1023934
07/02/11 03:20 PM
07/02/11 03:20 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
No calculator help, just guessing: @ 109+ in 3800 lbs through a 4-speed, I'm guessing you're making just shy of 500 horsepower at the motor. But the early stuff is killing you for sure. By comparison, My Satellite goes 12.20's at 112, and I figure I'm right at 500 HP with the car weighing in at 3775.
Get ready,...... here comes the sickness!
Re: 1st time at the dragstrip - help me estimate my hp? [Re: johnv] #1023935
07/02/11 04:24 PM
07/02/11 04:24 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The Moroso Speed Calculator puts you at about 395 net actual flywheel hp.
I would focus on getting a sure grip, maybe a better tire, track launching/driving/shifting practice and tuning before I would get to excited about what the HP is based on your one outing.
I bet you'll be in the low 12s @ 115 mph with a 1.9 sixty ft in no time.
Re: 1st time at the dragstrip - help me estimate my hp? [Re: buildanother] #1023936
07/02/11 04:51 PM
07/02/11 04:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and i couldn't agree more!
Re: 1st time at the dragstrip - help me estimate my hp? [Re: BSB67] #1023937
07/02/11 07:51 PM
07/02/11 07:51 PM
leawood, ks
johnv Offline OP
johnv  Offline OP
leawood, ks
Thanks, it sounds like a that calculator is a little more conservative than the one on the tech archives.
A sure grip is definitely in my future, but I intend the car more for a cruiser than drag racing, so the tires will most likely stay as the weak link.
My nature is to be skeptical about engine builders dyno results, so doing a sanity check was my main purpose (other than fun) for the trip to the dragstrip.
Thanks again,
John
Re: 1st time at the dragstrip - help me estimate my hp? [Re: johnv] #1023938
07/02/11 10:29 PM
07/02/11 10:29 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
The way your MPH is jumping all over the place its hard to say, I'm sure theres another 5 MPH or more in it, so lets say 114, thats in the 11s, your gears are hurting you, I see this alot but don't understand, why do guys build a somewhat monster style engine only to kill it with highway gears , if you want a cruiser, put a mild 318 in it!!
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
