magnum barrel intake modifications #1023794
07/01/11 01:03 AM
07/01/11 01:03 AM
Northwest
Four40mopar Offline OP
Northwest
Does anyone have input on triming the runners of the factory magnum barrel intake? Mopar Muscle had an article about doing this but I don't remember how much to remove. How much power will this add?
Re: magnum barrel intake modifications [Re: Four40mopar] #1023795
07/01/11 08:18 AM
07/01/11 08:18 AM
IN
ahy Offline
ahy  Offline
IN
Trimming the runners changes the "tuned length" and increases the tuned RPM. The shorter runners will wnt to make peak torque at a higher RPM and flow a bit better.
Hughes website has a article on this with more specifics.
The trimming modification needs to be matched with a hotter cam for benefit... if the manifold is trimmed with the stock cam, the two will be mismatched and the engine may lose performance.
