need help locating brake warning switch! #1023714
06/30/11 10:20 PM
06/30/11 10:20 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
In the brass junction block where the lines from the Master Cyl feed in,and the various brake lines
attach,there is a brake switch which flashes a warning light on the Dash in a '67 Plymouth..
Anyone know where to get a new one?? Even tho
My brake system has been bled,brake shoes adjusted,and the master cylinder is full,the Brake warning Light still flashes as soon as I hook up the wire to that switch,so I'm assuming
that the switch is bad??
Re: need help locating brake warning switch! [Re: gassy66] #1023715
06/30/11 11:04 PM
06/30/11 11:04 PM
L.A., CA
P
plysat Offline
plysat  Offline
P
L.A., CA
That junction block *is* the switch, mine's been acting weird too. Unfortunately, no idea where to get one.
Re: need help locating brake warning switch! [Re: gassy66] #1023716
07/01/11 12:59 AM
07/01/11 12:59 AM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
NAPA Knowhow!
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: need help locating brake warning switch! [Re: gassy66] #1023717
07/01/11 05:34 PM
07/01/11 05:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the light comes on as soon as the wire is connected, the spool inside the splitter isn't centered; in some cases it's necessary to remove the switch and manually center the spool.
If the spool keeps moving off center there is probably an imbalance in the system even if there is no air or external leaks. A master cylinder can fail internally and show no external signs of distress.
Re: need help locating brake warning switch! [Re: gassy66] #1023718
07/01/11 06:29 PM
07/01/11 06:29 PM
L.A., CA
P
plysat Offline
plysat  Offline
P
L.A., CA
Well, if anyone finds 'em, post a link... always good to have a spare!
Re: need help locating brake warning switch! [Re: John_Kunkel] #1023719
07/02/11 09:18 AM
07/02/11 09:18 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Thanks for info regards spool,I'll remove that
switch and check-don't think I have mstr cyl problem,I just rebuilt that B4 installing...Still would like to purchase new switch,am gonna take pix and then try NAPA as suggested.
Re: need help locating brake warning switch! [Re: gassy66] #1023720
07/02/11 04:39 PM
07/02/11 04:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The "switch" as they call it is only a contact that touches the spool (differential piston) to make a ground for the warning light, I'd be surprised to see one that needs replacement unless it's leaking.
