pick up tube #1023663
06/30/11 09:14 PM
06/30/11 09:14 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Will the pick up tube out of a 571 oil pan work in a 402 oil pan? Thanks
Re: pick up tube [Re: 70 buzz] #1023664
07/01/11 12:28 AM
07/01/11 12:28 AM
If they're (1) both "center sump" & not exactly centered but somewhat toward the front but is commonly referred 2 as a CS. (2) both the same as in baffled or non baffled. I'm assuming the flat sump bottom is the same depth on both (4 qts) then yes
