4 link preload #1023593
06/30/11 06:53 PM
06/30/11 06:53 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
am scaling the car today due to launching to the right last weekend. i had 50 lbs more on the right rear than left, was expecting to see less than that due to launching right. am thinking to increase preload to 60 or 75 lbs. is that to much or ballpark ok?
Re: 4 link preload [Re: eds dart] #1023594
06/30/11 07:59 PM
06/30/11 07:59 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
That's not out of line. Usually the more HP it makes, more preload will take. Shouldn't take more than a flat or 2. Little bit will go a long way if you already have 50# in it. How hard was it pulling to the right? Do you have a AR bar? With a AR bar you can usually get away with less pre-load. I still have a bit in my car to get it to launch nice and straight. Not exactly sure how much because my car needs to be re-scaled.
Re: 4 link preload [Re: Bigcube] #1023595
06/30/11 08:38 PM
06/30/11 08:38 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
car does have an AR, i had it disconnected when weighing. i run it with just taking the slop out of it. i found that a quarter turn either way on top bar was worth 30 or so lbs of preload. it didn,t pull very badly it just ,made an initial move to the right then went straight. going to try my luck at Muncie this weekend. Car ran pretty good last weekend and i was tearing the tree down, wish me luck, lots of hitters will be there .
Re: 4 link preload [Re: eds dart] #1023596
06/30/11 09:16 PM
06/30/11 09:16 PM
Guitar Jones Offline
I've never scaled my car so I don't know how much preload is actually in it but I have two full turns on the top right bar, no AR bar though I know I need one.
Re: 4 link preload [Re: Guitar Jones] #1023597
06/30/11 09:41 PM
06/30/11 09:41 PM
Out West
408strokerdart Offline
Out West
un-hook the anti roll bar on one side, set rear wheel weights as close as possible left to right with the car at race weight (with driver). After setting the corner weights, adjust the anti-roll links until the bolt will slide in without force.
Re: 4 link preload [Re: Guitar Jones] #1023598
06/30/11 09:48 PM
06/30/11 09:48 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Sounds like you know what the do How did is sixty?
Re: 4 link preload [Re: Bigcube] #1023599
06/30/11 11:34 PM
06/30/11 11:34 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
been out pumping fuel and loading the truck up. 1.40 and 1.41 when it would go right. didn,t seem to matter which lane which made me think i was pretty close and a little more preload would help.car definately doesn,t like equal rear weights.
Re: 4 link preload [Re: eds dart] #1023600
07/01/11 12:32 AM
07/01/11 12:32 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Do you have someone equal to your weight sitting in the drivers seat. If not you are lost when it comes to starting line corner weights. I set my car neutral. Then get someone equal to my weight to sit in car. Then I dial in however much preload it takes to make the car go straight. My antiroll is then installed neutral as it does not take on any part of the preload, just maintianing the stabilitly in the rear of the car.
Leon
Re: 4 link preload [Re: Leon441] #1023601
07/01/11 07:56 AM
07/01/11 07:56 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
My car takes 1.5 turns from neutral driver seated in car no antiroll. Good luck at muncie.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: 4 link preload [Re: moparmxz] #1023602
07/06/11 11:45 PM
07/06/11 11:45 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Did you get this deal straightened out, just curious what the cure was.
Re: 4 link preload [Re: moparmxz] #1023603
07/07/11 02:46 PM
07/07/11 02:46 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
1.5 turns or 1.5 flats?
Leon
Re: 4 link preload [Re: Leon441] #1023604
07/07/11 06:26 PM
07/07/11 06:26 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Leon
Turns ,it will go straight with less but then it would smoke one tire a little quicker than the other. A little extra and my tires wear even and it still goes straight.
Re: 4 link preload [Re: moparmxz] #1023605
07/07/11 06:49 PM
07/07/11 06:49 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
The high heat and track temp just killed the car. It wouldn,t 60 foot at all, it was all over the place. On Monday tried some throttle stop launch and that worked pretty good. Am going to try this again at INDY this weekend.
Re: 4 link preload [Re: eds dart] #1023606
07/07/11 10:20 PM
07/07/11 10:20 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You ever tried checking the thrust angle on the car. There is no way that car should need 1.5 turns of preload. You are compensating for something. Probably rear steer or dishrag frame.
Leon
Re: 4 link preload [Re: Leon441] #1023607
07/08/11 09:36 AM
07/08/11 09:36 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Leon
I assume you are talking to me,this is why i almost never post advice on here to much criticism. My frame is fine,and i,m a certified frame and body man. So i am positive the rearend is square and straight.I do have a short unequal 4 link,i do not have a frame stiff enough to run your kind of et,s. But i don,t think my car could be flexing much as the paint is 16 years old and the body has no stress cracks. I work with what i have and make the best of it. I just replied to Ed because i have talked to him and i like his car. Also i was not the one asking for advice. Now if you have some good advice for Ed i,m sure he would appreciate it.
Re: 4 link preload [Re: moparmxz] #1023608
07/08/11 01:20 PM
07/08/11 01:20 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
This car has been a continuing challenge to get it to hook in the high heat of summer. I realize heat affects all cars but mine seems to really change drastically for the worst. Much faster cars don,t seem to have as much trouble as mine getting down the track and that adds some frustration to the equation. For example over the winter made some changes to the 4 link, i shortened the bars and lowered the brackets to be able to get some lower IC points.This spring With outside temp of 66 tracktemp 97 car runs 1.36 60' 6.487 103.27 IC @ 41 long 6.5 high. that generated big wheelstand almost to the 60ft beams. fast forward to high heat last weekend 60,s detreriate to 1.43 with some really bad spinning 1.46 and high 6.55. No changes were made to the car and thats where my frustration comes from. I,m going to keep swinging at it but my hair is getting grayer.
Re: 4 link preload [Re: eds dart] #1023609
07/08/11 01:39 PM
07/08/11 01:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Where's the CG of the car... but if it was wheel standing
the IC was most likely forward of the CG.... also
whats the weight bias
Re: 4 link preload [Re: MR_P_BODY] #1023610
07/08/11 02:02 PM
07/08/11 02:02 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
I honestly dodn,t know the cg location. The weight bias is 55% front 45% rear. Just scaled car last week, see previous post, 1755 lbs front, 1423 lbs rear. lf 937 rf 816 lr 669 rr 754. left side total vs right side total was 50.5% left and 49.4% right. when i built the car i kept the engine/tranny factory offset. all numbers with driver weight in seat.
Re: 4 link preload [Re: eds dart] #1023611
07/08/11 03:58 PM
07/08/11 03:58 PM
gregsdart Offline
gregsdart  Offline
With that much weight over the nose, you will probably have to compensate with a more aggressive hit. Will probably also want as much front travel as you can muster, and loose.
