11.75 rotor #1023441
06/30/11 03:17 PM
06/30/11 03:17 PM
NC
P
phil4161972 Offline OP
P
NC
Hey guys, I have a 72 cuda with factory disc brakes. I have an adapter to put the 11.75" rotor on that spindle. Will the Wilwood caliper adapters sold by Mancini bolt onto the spindle I have? Or is there a factory Pin type caliper adapter that will bolt to my spindle and work with the 11.75" rotor? thanks for any input.
Re: 11.75 rotor [Re: phil4161972] #1023442
06/30/11 04:06 PM
06/30/11 04:06 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Yes and yes.
Re: 11.75 rotor [Re: TC@HP2] #1023443
06/30/11 04:33 PM
06/30/11 04:33 PM
NC
P
P
NC
Where would one find the pin type mount?
Re: 11.75 rotor [Re: phil4161972] #1023444
06/30/11 05:06 PM
06/30/11 05:06 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I got one from Dr Diff for my 11.75 using that caliper.
Re: 11.75 rotor [Re: DANA60] #1023445
06/30/11 05:19 PM
06/30/11 05:19 PM
NC
P
P
NC
Thanks for the help
Re: 11.75 rotor [Re: phil4161972] #1023446
07/03/11 11:13 PM
07/03/11 11:13 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
just get caliper adapter brackets off of a 76-mid 78 B-body (doba, Charger, Magnum) They used the 11.75" rotors and Pin Calipers. I scored a set and did the same swap on my factory disc 71 Challenger. (bearing spacer for the spindle, new 11.75" rotor, caliper adapter, and reused the caliper!)
1971 Challenger
