Re: Pick Up and Reluctor Gap
[Re: Kern Dog]
#1023377
07/01/11 08:18 PM
07/01/11 08:18 PM
RapidRobert
I'd toss some 68 or 70 pri jets in there for a 1 hour test to see if you can elim that it's lean (vac leak) & then work on electrical. Sounds simple but might want to start w a compression test. unhook/cap the vac adv for a quick test (rotor phasing) & see if that helps/hurts/no ch. does it do it hot/cold or always
[Re: Tony440]
#1023378
07/04/11 12:13 PM
07/04/11 12:13 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
YOU KNOW WHAT IS HARD? try to set the .008 gap on a MP or stock distributor ( same design )
once you set the gap on rest position, aply vacuum to the advance and will note HOW OFF will be the gap.
Reason for this ? THE RATIOUST WHAT MAKES THE PICK UP COIL ADVANCE is not the same than reluctor and won't meeet ever the reluctor circunference. Its imposible being the center of both circunferences are not the same
Some times you'll set the gap correctly and when start up your engine, will note the reluctor being cutting off by the pick up coil.
Trick! by trial and error, bent the pick coil bracket and pick up angle untill get the BEST average gap around on both positions, with vacuum and whitout vacuum being applied.
You can spent 2 days untill get the best setup as posible and not allways is reached out! I just finished to make this job on a SB dist for a buddy, and have done on my BB dist couple of times
measure with every reluctor end, and mill some ones if required
THEN ALSO CHECK how much play and tight pieces can be set around. The magnet force can be even close the gap if pick up baseplate it has lot of play around ( its a floating assembly ). The pivot rivet on pick up coil uses to have lot of play too, what makes this job even more tricky
I also have had to fill the vacuum stud with teflon tape to make a more tight assembly with pick up coil ( on the provision for that ) getting more precision on advance and less play on gap.
WONDERING HOW THE FACTORY MADE TO SET THIS CORRECTLY... were factory units better built than actual replacement parts ?
[Re: NachoRT74]
#1023379
07/04/11 12:34 PM
07/04/11 12:34 PM
NachoRT74
Valencia, España
BTW, the reluctor pin also CENTERS OUT THE RELUCTOR, so usually the 3 reluctor points around this pin will need to be sligthly milled out.
Shaft bushing affects A LOT the gap too, specially on BBs
[Re: RapidRobert]
#1023381
07/04/11 05:59 PM
07/04/11 05:59 PM
NachoRT74
Valencia, España
in fact, on the posted thread LOL, just read it about lol
welll it is a new update on a new thread ;D
