trying to fix an off idle stumble #1023289
06/30/11 10:22 AM
06/30/11 10:22 AM
Columbus, OH
Spanky Offline OP
Spanky  Offline OP
Columbus, OH
71 383 w/AVS. Engine stumbles initially, but if I keep the throttle open, it picks up again & pulls pretty hard. I've tried adjusting the accelerator pump in each direction & neither position stopped the stumble.
I'm starting to lean toward an ignition problem. The plugs were really fouled from a previously corrected problem, so I cleaned 'em up with carb cleaner & a wire brush. My timing light also seems to have a problem triggering off the ignition wires (the light works just fine on my factory wired Dodge Ram). I guess I'm just not sure it's a weak spark since I wouldn't expect it to pull hard after a couple of seconds of sumbling.
Any ideas?
Re: trying to fix an off idle stumble [Re: Spanky] #1023290
06/30/11 10:43 AM
06/30/11 10:43 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
I had a consistent off idle stumble with my 360 and 650AVS. I tried everything and finally read somewhere that the Eddy carbs don't like more than 5 psi of fuel pressure. I added a fuel pressure regulator, set it at 4.5 psi, and no more stumble....at all! It also idles cleaner.
Re: trying to fix an off idle stumble [Re: Mapandjlp] #1023291
06/30/11 12:03 PM
06/30/11 12:03 PM
Columbus, OH
Spanky Offline OP
Spanky  Offline OP
Columbus, OH
Never woulda thought of that one on my own. There's a Jeg's nearby; I'll see if they've got a regulator. It's using a stock mechanical fuel pump, but still wouldn't be a bad idea to see what kind of fuel pressure it's pushing. BTW, nice Challenger!
Re: trying to fix an off idle stumble [Re: Spanky] #1023292
06/30/11 01:31 PM
06/30/11 01:31 PM
Colo
P
PJ68RT Offline
PJ68RT  Offline
P
Colo
In my AVS i have to replace the accelerater pump 'piston' quite often or i get off idle stumble. The leather ring will loose its seal in the bore and not pump the proper amount of fuel. Just a thought...
Re: trying to fix an off idle stumble [Re: PJ68RT] #1023293
06/30/11 01:39 PM
06/30/11 01:39 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Look at the check valve in the accelerator pump well. If it is not holding you will get a weak pump shot.
Getting old just means you were smarter than some and luckier than others.
Re: trying to fix an off idle stumble [Re: Spanky] #1023294
06/30/11 03:05 PM
06/30/11 03:05 PM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
Thanks! It's a work in progress.
For what it's worth, mine has a new "stock" mechanical pump as well and it was pushing over 7 psi...
I picked up a Holly regulator and a simple Mr. Gasket gauge. Less than $60 for the whole setup and it works great!
