850 Demon vs. 750 Holley 3310 #1023169
06/29/11 11:56 PM
06/29/11 11:56 PM
Anonymous OP
Anonymous OP
The motor is a 77 440 with 9:1 compression, early 906 heads (milled a little to get the CR where it's at), a cast iron intake, .484 MP hydraulic, Hedman headers, MSD 6AL, 2,800 stall convertor, 3.55 gears, blah, blah....
Very mild build.
The intake will be replaced by Holley Street Dominator when I find a good used one.
I have the two carbs at my disposal and have always been happy running the 750 3310 on other similar combos. My experiance has been very good drivability and power for mild combo's.
Will the 850 Demon be too much?
Re: 850 Demon vs. 750 Holley 3310 #1023170
06/30/11 02:52 AM
06/30/11 02:52 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Very mild build.
I'm sure the 850 will be much, not enough stall & gears & especially if its a Mighty demon, I'd run the 750 3310 on a set-up like that sence you already have it.
Now on the compression, are these factory pistons? even if you mill those 906s alot i'll bet your not at 9.1 with the stock pistons, how much were they milled? The factory pistons on a 77 440 are a good .180" in the hole, the true compression is no higher then 7.8.1, the earlier blocks (68-71) had the pistons .080 in the hole, the compression on them were around 8.7.1, thats having the pistons .100" diffence between them, the pistons will have more affect in the compression on the placement of height then milling the heads the same amount. I milled a set of 452s on a 77 446 i had .050" & it raised the compression not even 1/2 point, so i was around 8.3.1 tops, The engine ran about the same, when the pistons are that far down its really hard to make a big difference in noticable power just milling the heads, but if you install a set of FTs higher up it makes a big differance, Going with a set .020" below deck is night & day. But if you have aftermaket pistons then scratch what i just said.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
