Need help with emblem #102308
08/10/08 11:34 AM
08/10/08 11:34 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
My son and I are trying to finish up on my 5 year resto on our 71 Chalenger and ran into a problem I did not think about when it went to paint. The car had a T/A style hood when we bought it but decided to go with the R/T hood wich was on the car when built. I had bought "340 Four Barrel" hood emblems for the hood but when I went to put them on, the hood had 3 holes and my emblem had 2 holes. It was suggested to cut the prongs off the back but it would not cover all the holes up. Any suggestions?
Re: Need help with emblem [Re: Shatar4] #102309
08/10/08 11:36 AM
08/10/08 11:36 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
pic2
Re: Need help with emblem [Re: Shatar4] #102310
08/10/08 12:56 PM
08/10/08 12:56 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
The only right way to fix it would be to weld it shut and repaint it.
Re: Need help with emblem [Re: Shatar4] #102311
08/10/08 03:04 PM
08/10/08 03:04 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
The 71 Challenger engine call-out emblems are different than the 70. They have a larger font.
I'm not sure of the stud count on the 71 emblems, but I would get one & check it out...
Re: Need help with emblem [Re: 318 Stroker] #102312
08/11/08 09:19 AM
08/11/08 09:19 AM
cataclysm80 Offline
cataclysm80  Offline
definately worth a shot.
Tav
Re: Need help with emblem [Re: cataclysm80] #102313
08/11/08 09:33 AM
08/11/08 09:33 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Don't you hate when something like that happens.
You guys have done a great job on the car. I also did not know there was a difference in the emblems and would have made the same mistake most likely. I looked in the Year One Catalog and they (for whatever reason) are not listing that emblem for 1970. They do show the emblem for 1971 and it is the same part number (FD40E)as 73 and 74 as well. Does not say if it is 2 or three prong.
Here is another possible option that is not 100% correct. What if you cut the bar out of the emblem between the 340 and the word "FOUR". That may allow you to separate it enough to cover the holes. You'd probably have to remove the studs on the back of the emblem also because the words wouldn't be too far apart if you tried to use them in the holes.
Joe
Re: Need help with emblem [Re: jrwoodjoe] #102314
08/11/08 11:30 AM
08/11/08 11:30 AM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
"Here is another possible option that is not 100% correct. What if you cut the bar out of the emblem between the 340 and the word "FOUR". That may allow you to separate it enough to cover the holes. You'd probably have to remove the studs on the back of the emblem also because the words would be too far apart if you tried to use them in the holes."
That's a awesome idea! I'm gonna give it some thought.
Re: Need help with emblem [Re: Shatar4] #102315
08/11/08 02:28 PM
08/11/08 02:28 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I can't remember, but if you can see the studs under the hood, then save them and glue them them in from underneath to fill the holes under the hood and it will look like the studs are coming through. You could get another emblem and get the studs off of that since you will be 2 studs short.
Joe
Re: Need help with emblem [Re: jrwoodjoe] #102316
08/23/08 12:46 PM
08/23/08 12:46 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Did you come-up a solution? Joe
Re: Need help with emblem [Re: jrwoodjoe] #102317
08/23/08 01:41 PM
08/23/08 01:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
70 & 71 emblems are not different the jumbo emblems started showing up in 72 on B bodies they weren't used on E bodies...The three hole pattern was only used for 440 SIXPACK or 426 HEMI emblems...The correct fix would be to weld up the holes & repaint...
Re: Need help with emblem [Re: 1_WILD_RT] #102318
08/23/08 04:57 PM
08/23/08 04:57 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I'm looking at the 1971 Dodge dealer brochure, & on a 71 Plum Crazy Challenger R/T with a R/T scooped hood it clearly shows a jumbo 440-six pack hood emblem.
The pic is in the desert, & it looks like a Kowalski wannabe standing next to the R/T...
Re: Need help with emblem [Re: 318 Stroker] #102319
08/23/08 05:06 PM
08/23/08 05:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The 440 SIXPACK & 426 HEMI emblems were bigger from the beginning...Which is why the hood required three holes...By 72 440-6 & Hemi were gone so 340 & 400 emblems got big to add flash since the cars weren't fast any more they needed "Flash"...
Re: Need help with emblem [Re: 1_WILD_RT] #102320
08/23/08 05:37 PM
08/23/08 05:37 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
What about the 70 Challenger w/ R/T hood. Were the SixPack & Hemi emblems the small or large ones?
Re: Need help with emblem [Re: 318 Stroker] #102321
08/23/08 11:10 PM
08/23/08 11:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There were no small 440 SIXPACK or 426 HEMI emblems used on a Challenger Rally Hood....
