Page 7 of 14 1 2 5 6 7 8 9 13 14
Re: Subframe connectors, which way should we #1021
01/21/04 12:16 AM
01/21/04 12:16 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Much thanks Max, just what I was looking for. No cold concrete here, or rust either ...maybe a move is in order??? All you have to deal with is the plastics turning to powder...oh well...a couple of months of hell beats winters icy grip for 5 months...
Re: Subframe connectors, which way should we [Re: pete] #1022
01/21/04 07:27 AM
01/21/04 07:27 AM
Clarkston,MI
Todd_DesMarais Offline
super street
super street
Clarkston,MI
WOW Pete........nice work !! so if I got this straight, when you cut the connector to the floor's contour, did you box it with the flange material, or just weld the flange to the sides? and how about those torque boxes ? home made or bought ??
More pics PLEASE !!!
Todd
aduC' 47 IIeredevleB 66 383 etilletaS 66 DTC 0053 MAR 50 "ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
Re: Subframe connectors, which way should we [Re: Todd_DesMarais] #1023
01/21/04 09:06 AM
01/21/04 09:06 AM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
I boxed them, the torque boxes are mine.
Thx Pete
Re: Subframe connectors, which way should we [Re: rapom] #1024
01/21/04 10:28 AM
01/21/04 10:28 AM
Thanks Rapom. So, what I can find on sale between .083 and .125 it is then .
Re: Subframe connectors, which way should we [Re: nomore65BelvJim] #1025
01/21/04 10:45 AM
01/21/04 10:45 AM
Hi Jim, I know enough about Arizona to miss it everyday. We have a 1/3 acre pie slice piece of land overlooking Lake Havasu. It is at the end of a Cul de Sac in Lake Havasu City. Bought it in the 60's, gonna built there one day.
Hope those jpegs helped.. Had to scrape the undercoat off, then weld after taking out the interior. Lotta work, but it's neat putting a jack in the middle of the car and jacking up the whole side of the Coronet., But if I had it to do over I wouldn't have done it with .125" wall. Too heavy.
Max
Re: Subframe connectors, which way should we [Re: pete] #1026
01/21/04 10:58 AM
01/21/04 10:58 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Now THAT is how SFC's OUGHT to be... I don't think I have that kind of patience, though. Ugh, that had to be a lot of work. Should be SCCA Street Modified-legal, though... no cutting of the floorpan to install. I just bought some 2x3x(3/16" = 0.1875") sticks to start mocking up my SFC's. They're thicker than I had wanted, but won't add too much weight to my car. It's all down low, anyway. I'll probably install some sheetmetal "struts" to tie the bar in to the floorpan once I get it tied in.
Nice job!
Clair
Re: Subframe connectors, which way should we #1027
01/21/04 02:36 PM
01/21/04 02:36 PM
Hey Max....Havasu, nice! C'mon out and visit sometime. The pics will be a great help...as soon as I clear out the garage and roll the shell in. The cover hasnt been off for over a year and its time to get back to work on it.
Re: Subframe connectors, which way shoul [Re: rapom] #1028
01/21/04 03:41 PM
01/21/04 03:41 PM
Rapom, what did you use to get the undercoating off? I am doing an under car cleaning, moving the springs, mini-tubs and connectors, on my 65 Belvedere 1.
I am about to hire a fulltime chiropractor to keep me going w/ the scraping..
So far, it's been paint stripper, kerosene,air putty knife,.. no workie!
About all I can make any progress at all with is the propane torch and scraper. That's fine for flat areas.. it's the corners, joints, uneven surfaces that are killin me!!
Yours looks great! Are you going to sand it down and paint ??
Re: Subframe connectors, which way shoul #1029
01/21/04 03:44 PM
01/21/04 03:44 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Anyone use the new magnum force subframe connectors?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Subframe connectors, which way shoul [Re: Kam*Kuda] #1030
01/21/04 03:52 PM
01/21/04 03:52 PM
Anyone have some pics for install on an EBody? Went out in the garage this afternoon looking through my scrap heap, and low and behold, some .083 wall 2X3 from when I did my subframe connectors and cage in my Mustang. I ran my connectors through the floor on my Mustang, but did not really want to do that on my Chally. Looking under the car looks like I have plenty of room @ the torsion bar/subframe mount, but toward the rear subframe, runs out of room. So, anyone have some pics they would like to share. I really do not want to cut my new floorpans
Re: Subframe connectors, which way shoul #1031
01/21/04 04:19 PM
01/21/04 04:19 PM
Atlanta, GA/Blue Ridge GA
NotaHemi Offline
super street
NotaHemi  Offline
super street
talk about getting in on this post late, but should the engine be in the car to do the connectors. Mine is still on the stand waiting to go to the machine shop.
Any disadvantages to doing the cage, SFC without the weight in the nose?
1974 Dodge Challenger 440 restoMod. 2006 Range Rover HSE 2004 Toyota Sequioa Ltd 4x4
Re: Subframe connectors, which way shoul #1032
01/21/04 05:18 PM
01/21/04 05:18 PM
Clarkston,MI
super street
super street
Clarkston,MI
Hey 71challenger, I believe member Pete's car (six or so posts up) is an e-body/71 up b-body. however, his connectors are a little more complicated by the looks of things. beautiful job though, and factory looking to boot.
I also have a cuda that will get connectors someday, and share your concern. I was going to do like Tim did on his Charger, and bend the connectors to fit, but now I think Pete's way is the ticket !
Hows about some more pics Pete ??
Todd
Re: Subframe connectors, which way shoul [Re: Todd_DesMarais] #1033
01/21/04 06:20 PM
01/21/04 06:20 PM
Yeah I saw that, he did a great job. I am just hoping I can stay away from cutting up my new floor pans .
Re: Subframe connectors, which way shoul #1034
01/21/04 06:31 PM
01/21/04 06:31 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Oldtimer, I started in Nov. and finished in mid Dec.
I tried EasyOff oven cleaner first and it didn't seem to do the job to well. I ended up using a torch and scrapper to do the job. Just worked on it about and 1and 1/2 hours a day. After I'm done with my tubs I'm going to go through rags and Kerosine or Brake cleaner to get off the residue. Then I'm going to Sand Blast everything before painting the undercarriage with Zero Rust. I am using a specialized scrapper that enabled me to get 99.5% of all areas. I'll take a picture of the scrapper later on and post it on this post. I'm pretty sure you can get it at any hardware store.
Re: Subframe connectors, which way shoul #1035
01/21/04 06:43 PM
01/21/04 06:43 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
Have you seen the new subframe connectors that Magnumforce Race Car fabrication is selling? A bit spendy but they appear to have three point attachment, do not require floor cutting and tuck up real nice under the car.
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: Subframe connectors, which way shoul [Re: origcharger] #1036
01/21/04 06:51 PM
01/21/04 06:51 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I used a propane torch + gasket scraper to get the undercoating off. It comes off easy when it's hot. Then afterward a quick spray with carb cleaner/wipe off prepped it for welding.
Rich H.
Esse Quam Videri
Re: Subframe connectors, which way shoul [Re: origcharger] #1037
01/21/04 06:59 PM
01/21/04 06:59 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Here is the Magnumforce Race Car pieces. I think I'll go home made and save some big bucks.
Re: Subframe connectors, which way shoul [Re: rapom] #1038
01/21/04 07:34 PM
01/21/04 07:34 PM
Looks like I'm not too far off w/ the torch and scraper!! Damn! I'm tooooo old for that torture!!
Thanks everyone for the input.. Back on my back..Now I know how a hooker feels!!
Re: Subframe connectors, which way shoul [Re: BADBEE] #1039
01/21/04 08:08 PM
01/21/04 08:08 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Here are some pictures of how I did my 68 Barracuda using 2x3x1/8 tubing. And yes I have some scraping to do on my undercoating. The connectors are not completely done in the pics but you will get the idea.
Jesse
Re: Subframe connectors, which way shoul [Re: 68Fastback] #1040
01/21/04 08:11 PM
01/21/04 08:11 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I will try this again for the pictures
