12 volt cooling fan-reversing polarity #1022561
06/29/11 08:28 AM
06/29/11 08:28 AM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
Hi
I wanna put an electric fan on the car.I need it to run backwards to make it a pusher fan in front of the radiator,but when I wire it to run in reverse the wires get hot in a matter of seconds.s this possible in some way to do, or do I need a voltage limiter,I wouldnt think so 12 volts are 12 volts,but I've been wrong once or twice before.the negative wire was just touching and not bolted down tight,It worked alright when powering it with a battery charger....hummm
Re: 12 volt cooling fan-reversing polarity [Re: mikepar] #1022562
06/29/11 08:41 AM
06/29/11 08:41 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
id try to snug that neg down tight and try it again.
Re: 12 volt cooling fan-reversing polarity [Re: mikepar] #1022563
06/29/11 08:46 AM
06/29/11 08:46 AM
Jacksonville Florida
elitecustombody Offline
If that motor and fan blade combo was not designed to be a pusher, it will never do what it was designed to do and make very small difference if any
Re: 12 volt cooling fan-reversing polarity [Re: mikepar] #1022564
06/29/11 02:17 PM
06/29/11 02:17 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
An engine cooling fan in reverse is an engine heater?
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 12 volt cooling fan-reversing polarity [Re: 70Coronet500Vert] #1022565
06/29/11 04:03 PM
06/29/11 04:03 PM
crlush Offline
crlush  Offline
I had one that you had to turn the fan blades around or it wouldn't blow much air. on a 12v motor all you have to do is switch the wires to reverse.
Re: 12 volt cooling fan-reversing polarity [Re: crlush] #1022566
06/30/11 12:27 PM
06/30/11 12:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I had fans that suggested turning the blade around backwards too. Not putting much thought into it, I tried it.
DUH! That's just plain stupid and will not work. I have no idea how they got away with putting that in print.
Think about it. The motor turns the same way. The blades are angled. Now, what happens when you flip / 180 degrees on a vertical axis? It look an awful lot like /.
To get \ out of / would require removing the blades from the hub and sticking them on the opposite side of the hub. I don't think super glue is going to do the trick here.
- Stu Harmon
