Stainless Steel Lines or not? #1022262
06/28/11 09:41 PM
06/28/11 09:41 PM
Montreal PQ, Canada
74_360_Cuda Offline OP
Montreal PQ, Canada
Is it true that stainless steel lines (Brakes & Fuel) are proned toleak?
There is not a significant differance inprice... what would you recomend?
Re: Stainless Steel Lines or not? [Re: 74_360_Cuda] #1022263
06/28/11 09:50 PM
06/28/11 09:50 PM
IN
ahy Offline
ahy  Offline
IN
Th stainless is harder and doesn't seat as well on compression fittings which can cause leaks. It also requires a high end flaring tool if you make modifications. I went with mild steel for my brake andf fuel lines. I knew I would be cutting and flaring and didn't want to deal with the leaks. Plus the original steel lasted well for 40 years so I'm not too worried about corrosion on a car that will not be driven in winter salt conditions.
Re: Stainless Steel Lines or not? [Re: 74_360_Cuda] #1022264
06/28/11 09:52 PM
06/28/11 09:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Stainless. I haven't had any issues with the stainless lines. If your fittings are messed up it may leak, but plain lines might leak also.
Re: Stainless Steel Lines or not? [Re: 451Mopar] #1022265
06/28/11 09:55 PM
06/28/11 09:55 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
with having Galvinized steel lines over stainless for the same reason
Re: Stainless Steel Lines or not? [Re: johnscudashop] #1022266
06/28/11 10:22 PM
06/28/11 10:22 PM
desomod Offline
desomod  Offline
I have stainless and cannot stop a weep at one of the M/C fittings. Any suggestions?
Re: Stainless Steel Lines or not? [Re: 74_360_Cuda] #1022267
06/28/11 10:33 PM
06/28/11 10:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I prefer stainless lines, they always look good, never rust or flash rust, and if you like a little bling, they buff out super easy with just a cloth and polish before install,....I like to do the car once, that's it, you want to avoid leaks, regardless of the line, stainless or steel, use the proper tubing wrenches, and on stainless, use some liquid teflon on the treads, never had a leak, and I've done plenty of cars and trucks with stainless, not just brake, but fuel, emissions, etc, basically everyline in the car
Re: Stainless Steel Lines or not? [Re: 74_360_Cuda] #1022268
06/28/11 11:44 PM
06/28/11 11:44 PM
Tampa Bay, Fl
sb4evr Offline
sb4evr  Offline
Tampa Bay, Fl
I won't go stainless again. It doesn't appear correct(too shiny) and the stuff can be very hard to seal as many have attested to. It isn't worth the hassle.
If you go to a salvage yard you will find many vehicles there that have very good looking brake/fuel lines on them and they have seen more weather than your car would ever see again in its life.
Save your money for something more important.
Re: Stainless Steel Lines or not? [Re: sb4evr] #1022269
06/29/11 12:07 AM
06/29/11 12:07 AM
Montreal PQ, Canada
Montreal PQ, Canada
Wow, I was not expecting such a debate!
Re: Stainless Steel Lines or not? [Re: 74_360_Cuda] #1022270
06/29/11 08:07 AM
06/29/11 08:07 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yea I don't think stainless is worth it either. Like what was said mild steel lines will last another 40 years.Ton's easier to work with also.
Tips on getting stainless to seal. Lube the fitting real well and tighten and loosen a few times, the lube will allow you to get it really tight. What PIA stainless is.
Re: Stainless Steel Lines or not? [Re: Challenger 1] #1022271
06/29/11 08:17 AM
06/29/11 08:17 AM
VA
AtomicDog Offline
AtomicDog  Offline
VA
I experienced the same leak issue when installing a full set of pre-bent stainless steel brake lines on my '96 RAM 2500 4x4 truck. Best advise I can give is to definitely check for leaks after installing and keep tightening the fittings until all leaks are stopped. Sometimes, I tightened the fittings so much, I didn't think I could tighten them anymore, but finally did get all leaks stopped. Stainless is some hard stuff, but in the end, looks great and will be the last set of brake lines that truck will ever see!! I had rust issues with the OEM mild steel lines and didn't want to deal with that in the future again. Also, never wanted to have a metal brake line failure in a 3/4 ton truck while on the road, so I felt stainless was cheap long term insurance. Just need a good set of flare nut wrenches (and sometimes crowfoots) to install the lines properly.
Re: Stainless Steel Lines or not? [Re: AtomicDog] #1022272
06/29/11 08:22 AM
06/29/11 08:22 AM
Owosso, Michigan
stateroadhog Offline
Owosso, Michigan
Like the man said a little liquid teflon on threads and flare will seal it right up without having to over tighten
Re: Stainless Steel Lines or not? [Re: stateroadhog] #1022273
06/29/11 08:46 AM
06/29/11 08:46 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
MY 72 cuda is all stainless. Not one leak from get go.
Re: Stainless Steel Lines or not? [Re: 74_360_Cuda] #1022274
06/29/11 10:22 AM
06/29/11 10:22 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..isn't stainless 37 degree as opposed to 45 for regular lines...they can still seal with this mismatch but not as easily.
..stainless won't look stock though.
Re: Stainless Steel Lines or not? [Re: can.al] #1022275
06/29/11 11:14 AM
06/29/11 11:14 AM
NY usa
540challenger Offline
NY usa
SS should be 45* like the mild steel. AN fittings however are made on a 37*
Re: Stainless Steel Lines or not? [Re: 74_360_Cuda] #1022276
06/29/11 11:38 AM
06/29/11 11:38 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I chose stainless pre-bent for my Duster. I had to re-tighten one fitting on the distribution block after install. I had no other issues, though.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Stainless Steel Lines or not? [Re: bigsbigelow] #1022277
06/29/11 12:38 PM
06/29/11 12:38 PM
crlush Offline
crlush  Offline
Never had any problems with stainless leaking, if you make them yourself oil helps while flairing, and as long as you have a decent flairing tool you won't have any problems, the one I have cost me $40 bucks. Also they say if you use a cut off wheel instead of a tubing cutter to cut your lines it won't work harden the steel making it easier to flair.
