318 oil and trans pan gasket replacement #1022229
06/28/11 09:02 PM
06/28/11 09:02 PM
Ohio, USA
Donny Offline OP
Donny  Offline OP
Ohio, USA
Engine oil pan and trans pan both have bad leaks, never changed the gaskets on a small block before, it is a long pain in the ass job? Had a local mechanic said he hated doing them on 318's, which is what I have in a 69 Dart.
No garage at home to do it in so I am thinking of paying a shop to do it.
Any advice?
Re: 318 oil and trans pan gasket replacement [Re: Donny] #1022230
06/28/11 09:14 PM
06/28/11 09:14 PM
RapidRobert Online content
RapidRobert  Online Content
He means he hated doing the SB in an A body, the trans will b easy for you. Get the good pan gasket at the dealer 4295875AC & a filter & can easily adj the inside band while you are in there but are you sure it's the pan gasket leaking as tranny leaks can b very deceptive & there's several other places (on the trans) it could b.
