Saving E body door panels #1022113
06/28/11 06:46 PM
06/28/11 06:46 PM
Los Angeles, CA
71_dramaqueen Offline OP
Los Angeles, CA
So I have some really chalky white door panels in my challenger. I would like to save them because they are otherwise in good shape…. and I’m poor. I have seen the treads where members have lightly blasted and painted panels, and sanded a lot and texture painted.
I have a dash and paintjob that is black. Is sanding the chalk off and painting black just asking for trouble/ bad looking scratches?
Has anyone used a heat gun or used fiberglass resin over the panels? I don’t care if it has the right texture.
Thanks folks
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: Saving E body door panels [Re: 71_dramaqueen] #1022114
06/28/11 07:24 PM
06/28/11 07:24 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
waste of time since they will continue to fall apart
Re: Saving E body door panels [Re: 71_dramaqueen] #1022115
06/28/11 07:43 PM
06/28/11 07:43 PM
Central Pa. U.S.A.
Bigfury Offline
Bigfury  Offline
Central Pa. U.S.A.
Ir would seem a bit difficult to apply resin thin enough to do any good.Most likely would become brittle then even worst than what you started with.Don't know if a rattle can of SEM flexible primer surfacer might give ya some time.No matter what once the sun beats on something long enough with no protection it pretty well shoot ( look at some people who think it's great to get a super tan)
Re: Saving E body door panels [Re: 71_dramaqueen] #1022116
06/28/11 07:56 PM
06/28/11 07:56 PM
Chicagoland
cudastruction Offline
Chicagoland
The sun has broken down the plastic that made the door panel. The only thing you can do is sand down the door panel until you reach "good" plastic. Find some product that could build up the area that you sanded (which I don't know of any). Re-texture the panel (which will never match the original).
So, your only real options are to replace your panels or send them out to Just Dashes for them to recover them.
Re: Saving E body door panels [Re: cudastruction] #1022117
06/28/11 09:59 PM
06/28/11 09:59 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Yeah , your better off either buying good repros or having them recovered by just dashes. anything else you do would not look right.
Re: Saving E body door panels [Re: johnscudashop] #1022118
06/28/11 10:10 PM
06/28/11 10:10 PM
Los Angeles, CA
Los Angeles, CA
everyone here says all the repos for challengers are bad quality, not worth the money. What kind of $ would i be looking at for just dashes?
Re: Saving E body door panels [Re: 71_dramaqueen] #1022119
06/28/11 10:54 PM
06/28/11 10:54 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Once chaulky they are fried and if you sand them your grain will be gone. Most colors didnt hold up but good used black Challenger panels are not that hard to find and you can paint them white. Place a wanted ad in the Ebody parts section here on Moparts. I have a friend who probably has a set.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Saving E body door panels [Re: 71_dramaqueen] #1022120
06/28/11 11:20 PM
06/28/11 11:20 PM
Chicagoland
Chicagoland
Yeah, a little patience and you will find someone with a set to sell. You can try e-bay too. Sometimes you can find a good set for a reasonable price there but a want ad here is prolly your best bet.
Re: Saving E body door panels [Re: 71_dramaqueen] #1022121
06/28/11 11:42 PM
06/28/11 11:42 PM
Rhode Island
jml19621 Offline
jml19621  Offline
Rhode Island
I have done this in the past with good results. Take the panels and wash them with Dawn dishwashing detergent. Actually I have poured the Dawn right on the panels. I used a soft nylon brush and scrubbed the life out of them. Rinse them off and repeat the process a couple of times. Dawn is great for getting grease and oil off of parts. I then put some laqure thinner on a rag and wipe the panels down. After everything has dried I painted them with a product from Krylon called Fusion. I put on several thin coats over a few days allowing time for everything to dry between coats. After the final coat has completly dried I put on a few coats of Krylon clear coat.
If these panels a trash this is worth the shot. It is quick, it is easy, and it is cheap. The panels on the Cuda I am currently driving was done like this and they have held up fine.
Jeff
Re: Saving E body door panels [Re: 71_dramaqueen] #1022122
06/29/11 03:12 PM
06/29/11 03:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I'm still finding good used black panels for less than $200
Get those and paint 'em
Re: Saving E body door panels [Re: 71_dramaqueen] #1022123
07/03/11 08:24 PM
07/03/11 08:24 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
. well that was true until Metro started doing E body panels. The new Challenger panels should be out this summer.....and if you want to have your Orig panels done by Just Dashes, you may spend just as much as the new ones from Metro. Your best bet would be to find a better set and dye them if your low on cash
Re: Saving E body door panels [Re: 71_dramaqueen] #1022124
07/04/11 11:38 AM
07/04/11 11:38 AM
NJ
moparply Offline
moparply  Offline
NJ
I see the nice original passenger Cuda door panels for around $150-$200, they have good finish and minimal scratches, no cracks, ready to install panels.
The drivers are around the same or a little more in the same condition.
Re: Saving E body door panels [Re: moparply] #1022125
07/04/11 12:24 PM
07/04/11 12:24 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
What I dont understand is why nice originals dont sell for MORE than the repops if all the repops are so bad.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Saving E body door panels [Re: HemiRick] #1022126
07/04/11 12:49 PM
07/04/11 12:49 PM
NJ
moparply Offline
moparply  Offline
NJ
How much are the repops?
Your right, originals in mint condition should sell for a lot more then the repops.
Re: Saving E body door panels [Re: moparply] #1022127
07/05/11 07:55 PM
07/05/11 07:55 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
http://buymetroparts.com/
