Ebody convertible wheel house-where to cut !!
#1022039
06/28/11 05:00 PM
06/28/11 05:00 PM
Posts: 417 Caledon, Ontario
smac77
Caledon, Ontario
Hey Guys,
Does anyone have a factory bulletin/template or specs of the measurements on where to cut the wheelhouses before fitting the convertible "caps" on them...
Thanks, Shawn
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
Re: Ebody convertible wheel house-where to cut !!
[Re: cudastruction]
#1022041
06/29/11 12:22 AM
06/29/11 12:22 AM
smac77
Caledon, Ontario
I used the old ones as my template once I separated the cap from the wheel house.
Check out these guys... http://www.musclecarrestorations.com/
they have a cuda that they did it to with good picks.
Al
Thanks for the post Al, I can do that if needed without a problem, but I was hopeing someone had original specs handy for the procedure to save some time... the customer is going to be into enough hours as it is already... and his originals had been butchered by another "restoration" shop, so templating off them would take some time !
