Re: Shock absorbers
[Re: 73-Dart-sport]
#1021030
06/27/11 11:57 AM
06/27/11 11:57 AM
Posts: 2,515 PA
moparacer
PA
If I jack mine up in the garage then set the front end back down I have to back it up and pull it forwards while turning the wheel back and forth to get the front to settle back down.
It sets 2 or 3 inches higher then it should if I dont do that.
Its from the suspension binding due to the alignment on mine.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Shock absorbers
[Re: moparacer]
#1021031
06/27/11 12:10 PM
06/27/11 12:10 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Have you checked the gap between the lower bump stops and the frame, one of my torsion bars is a little weak and it sags like that, i've wound that side up a little more to keep it level. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: Shock absorbers
[Re: deaks]
#1021032
06/28/11 03:15 AM
06/28/11 03:15 AM
Posts: 2,864 IN
Irun5snd8th
IN
My AFCO's have been on the rear of mine for 3+ years. I just took them off a couple weeks ago and had them dyno'd and told them to rebuild them. They put them on the dyno and showed me the sheets and said; what do you want us to do with them??? They look perfect. Thats literally thousands of miles riding in the trailer and about 800 passes down the track. Hope that helps
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
