A833 reverse almost impossible to get #1020521
06/26/11 10:33 AM
06/26/11 10:33 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey guys,
I think by now every 4 speed guy on here is sick of the problems I have been asking about, but im here to bother all one more time lol
I finally got my A833 shifting great in all forward gears with no problems at all (Im using a vertigate shifter with a reverse lockout feature) but when I go to get reverse it is VERY HARD. I have to try about 5 or 6 times and sometimes it will still not go in. I have to slam the reverse lever, and even when i think its in, its not because I can feel it jump right out. The reverse ball and detent were all in the correct spots last time i had the trans apart (earlier this week)
I tried pulling off the tab for the reverse lever and just engaging reverse right off the side cover and I can see why its very hard with the lever attached- it is almost just as impossible for me to get reverse from the sidecover alone!
I am hoping it may be a sidecover issue as discussed in this thread that I did a search on.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=928314&an=0&page=13
But before I go yanking just the sidecover id like to get more opinions to see if its something more serious that I have to pull the whole trans out for (AGAIN! )
Any opinions are greatly appreciated!
Re: A833 reverse almost impossible to get [Re: mshred] #1020522
06/26/11 01:33 PM
06/26/11 01:33 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Try loosening the side cover without removing it. Then tap it up from the bottom rear area with a hammer. There is an interference fit on the 1-2 lever that will hit the reverse arm sometimes. NOTE: When putting the trans back together, ALWAYS put it in reverse before installing the side cover. After you tap the side cover upwards, try manually shifting it into reverse. If it goes leave it there and tighten the side cover bolts.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A833 reverse almost impossible to get [Re: 68LAR] #1020523
06/26/11 04:31 PM
06/26/11 04:31 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
As often as this comes up it should be high up in the Tech Archives.
Re: A833 reverse almost impossible to get [Re: GomangoCuda] #1020524
06/26/11 04:38 PM
06/26/11 04:38 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep. I experienced it last year. Mine would go into reverse OK, but really required force to get it out of reverse. Slight upward shift of the side cover and it was fixed.
Re: A833 reverse almost impossible to get [Re: Pacnorthcuda] #1020525
06/26/11 05:09 PM
06/26/11 05:09 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
thanks for the info guys, i kinda figured this was what it was (im glad its a simple fix too).
One question though, are you guys using shouldered bolts on your side covers? Mine are all shouldered bolts and im just wondering if this moving of the side cover is possible when using shouldered bolts that would kinda direct where it lines up
Re: A833 reverse almost impossible to get [Re: mshred] #1020526
06/26/11 05:12 PM
06/26/11 05:12 PM
Yes I have the shouldered bolts. The amount of movement is small (maybe .010???). The bolts will allow for it.
Re: A833 reverse almost impossible to get [Re: 68LAR] #1020527
06/27/11 05:22 PM
06/27/11 05:22 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
would I be able to do this if i have used silicone (permatex the right stuff to be specific) to seal the side cover? I just remembered that I dont have a gasket on there, and if i have to take the side cover off to reseal it then i think getting the cover back on the forks would be a bear
or is it as easy as just tapping it with it loose and not breaking the seal of the silicone? Im guessing im going to have to drain the fluid too
Re: A833 reverse almost impossible to get [Re: mshred] #1020528
06/27/11 05:26 PM
06/27/11 05:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Depends on how pliable the right stuff is , the cover needs to MOVE .
Re: A833 reverse almost impossible to get [Re: JohnRR] #1020529
06/27/11 06:17 PM
06/27/11 06:17 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
well i ordered a gasket from the dealer...Just worried that it will leak since even with the right stuff i had the old synchromesh leaking in one spot.
Im assuming its possible to get the cover back on the forks with the transmission in the car, just a very hard and annoying procedure I imagine?
Re: A833 reverse almost impossible to get [Re: mshred] #1020530
06/28/11 12:53 AM
06/28/11 12:53 AM
New York
EF8aar Offline
EF8aar  Offline
New York
It's not a too bad. I used Permatex High Tack to hold the gasket to the sidecover, then used a long thin screwdriver to guide the forks onto the gearshift levers. I then started anchoring the sidecover with the rear middle long sholdered bolt with no lockwasher to make sure it seat well in the countersunk hole, continued around the sidecover and came back to the middle rear bolt and installed the lock washer. Torque all bolts to 15 ft/lbs and you should be good to go.
http://www.permatex.com/products/automot...ket_Sealant.htm
Re: A833 reverse almost impossible to get [Re: EF8aar] #1020531
06/28/11 03:56 PM
06/28/11 03:56 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is the situation that seems to be a problem. As I noted, sometimes I've had to grind to get enough clearance to get a smooth engagement.
Re: A833 reverse almost impossible to get [Re: 6PakBee] #1020532
06/28/11 06:28 PM
06/28/11 06:28 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I have only had this be an issue on the 67 and newer trans (with the long shoulder bolt by the reverse switch) In this situation I machine .010" off the shoulder bolt which gives you an extra .005" clearance to move the side cover up. I only do this when both A and B 1/2 shift lever assemblies have been tried.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: A833 reverse almost impossible to get [Re: 64dodge572] #1020533
06/28/11 10:08 PM
06/28/11 10:08 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Dan
what do you mean by A and B shift lever assemblies?
I finally got the gasket today so its just a matter of doing the deed now (not looking forward to it)
Re: A833 reverse almost impossible to get [Re: 6PakBee] #1020534
06/28/11 10:10 PM
06/28/11 10:10 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Should I follow the procedure mentioned in the manual, or should I try just moving the cover first? I dont have any extra tabs lying around, and im not sure how to distinguish A from B
i just saw now that your diagram has a little blurb of where to grind ...but if I want to do that im thinking the whole transmission has to come out and apart again, which im not looking forward too..hopefully moving the cover will help, if not i guess I have no choice
Re: A833 reverse almost impossible to get [Re: mshred] #1020535
06/29/11 08:11 AM
06/29/11 08:11 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
As has been mentioned the steps that you should take (in this order)
1) Try shifting the cover up slightly to get clearance (this is the first procedure in the FSM)
2) Try the selective fit interlock levers, (this is just changing them until you have clearance, I don't know a current source of these but someone may)
3) Grinding for clearance (this is the last resort and yes, you have to disassemble the trans..try shifting the cover though first, I've only had to grind on one trans in 40 years of doing this)
Good luck
Re: A833 reverse almost impossible to get [Re: 6PakBee] #1020536
06/29/11 09:27 AM
06/29/11 09:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good luck
What about grinding the 1/2 lever for clearance ?
Re: A833 reverse almost impossible to get [Re: JohnRR] #1020537
06/29/11 04:41 PM
06/29/11 04:41 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Good luck
IIRC, the contact point on the 1-2 lever has a 'shoulder' on it and you'd be up against the shoulder when you are grinding. But there's nothing saying it couldn't be done. As a personal note, if I'm hand finishing something, I always have more luck holding a true surface on a convex surface rather than a concave so the reverse lever was the choice for me.
