904 in duster 340? #1020497
06/26/11 09:40 AM
06/26/11 09:40 AM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
Could you get a duster 340 with a 904 trans in 1971? Im looking at a car that supposedly has the original drivetrain but it has the 904/340 combo.
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: 904 in duster 340? [Re: Fishmarket] #1020498
06/26/11 09:56 AM
06/26/11 09:56 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
nope
Re: 904 in duster 340? [Re: Fishmarket] #1020499
06/26/11 09:58 AM
06/26/11 09:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No it wouldn't but it's easy enough to tell , look for the VIN
Re: 904 in duster 340? [Re: Fishmarket] #1020500
06/26/11 10:33 AM
06/26/11 10:33 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
No.
It is possible a car could have been mis-built, stranger things have happened. The VIN stamping on the trans case will tell the tale.
Re: 904 in duster 340? [Re: gdonovan] #1020501
06/26/11 11:11 AM
06/26/11 11:11 AM
That'll give you bargaining power & for sure b even more critical on inspection/questioning for what else may have been altered (for better or worse) but if not OE that's is a major blow esp as it cant b cheap
