Standard port head with Max wedge size ports, ????
#1020385
06/25/11 10:11 PM
06/25/11 10:11 PM
Posts: 736 New York
R/T1968R/T
New York
Built a motor for a friend about 25 years ago. The heads were 516 closed chamber ported a ton!!! There was no welding on the heads. The owner said he used a 440-1 manifold that fit. I told him the ports cant be that big. The Max Wedge gaskets were too big. he sent me this picture. The gasket is covering the heat crossover. Can anyone figure out what port size this is??
Re: Standard port head with Max wedge size ports, ????
[Re: RemCharger]
#1020388
06/26/11 10:05 AM
06/26/11 10:05 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
No heat crossover . they're max heads. Look alot like the ones we're putting on my brothers 383. You'll likely need to weld a standard port intake to use em. (ie most intakes,, victor,,)
Read his post again he says the gasket is covering the heat crossover .
[Re: JohnRR]
#1020389
06/26/11 10:19 AM
06/26/11 10:19 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Covering the cross over isnt a problem unless you run in cold weather.If the 440 1 has max ports it probally wont work.Rocky
Chrysler Firepower
[Re: R/T1968R/T]
#1020391
06/26/11 04:00 PM
06/26/11 04:00 PM
Posts: 1,443 Maryland
Dads426
Maryland
The 440-1 heads are max wedge port size (they match the max wedge intake gasket). We run them on our big motor.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
