Rear leaf springs
#1020376
06/25/11 09:51 PM
06/25/11 09:51 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
Anybody know how many leafs are supposed to be in the rear pack for a 1936 Plymouth/Dodge coupe? Leafs now have 10 pieces.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
Re: Rear leaf springs
[Re: 36PLYM]
#1020380
06/28/11 09:34 PM
06/28/11 09:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Sounds about right, my 38 Plymouth had about that many leafs, too. The tin cover was to hold the grease in, you were supposed to grease the leafs every so often, if it's wasn't 105 out I would get in the attic and dig out my FSM for the 38.
[Re: 36PLYM]
#1020381
07/03/11 01:45 AM
07/03/11 01:45 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
are they the orignal type spring ??? much narrower then modern springs,,,
i dont have an orignal set any longer but sound like a lot of leafs,,
Springs are original narrow springs, 1 3/4 inches wide. To clarify there are 10 leaves.
do you meen 10 full length leafs ?? im going to ask a friend to count his,,,they use to be my orignal 1940 leafs,,and they would be the same as yours,,,i now run posie,s super slide leafs,,,car sits 1 1/2 inch lower and rides nicer
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#1020382
07/03/11 10:43 AM
07/03/11 10:43 AM
36PLYM
Lithonia, Ga
At the rearend U bolts there are ten leaves stacked up.
