Rear leaf springs #1020376
06/25/11 09:51 PM
06/25/11 09:51 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Anybody know how many leafs are supposed to be in the rear pack for a 1936 Plymouth/Dodge coupe? Leafs now have 10 pieces.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Rear leaf springs [Re: 36PLYM] #1020377
06/28/11 12:24 AM
06/28/11 12:24 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
are they the orignal type spring ??? much narrower then modern springs,,,
i dont have an orignal set any longer but sound like a lot of leafs,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Rear leaf springs [Re: fstfish66] #1020378
06/28/11 12:44 AM
06/28/11 12:44 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I can't find a listing for the number of leafs in the 30s spring packs. Most I remember seeing were all wrapped with tin and the tin was only removed when the rear end reached the ground, mostly....
Seems to me the few I saw without the tin wrap had 5 or 6 leafs in the spring pack. That would match up with your 10 pieces, two pieces per leaf, they usually broke at the center bolt. Gene
Re: Rear leaf springs [Re: fstfish66] #1020379
06/28/11 02:49 PM
06/28/11 02:49 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Springs are original narrow springs, 1 3/4 inches wide. To clarify there are 10 leaves.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Rear leaf springs [Re: 36PLYM] #1020380
06/28/11 09:34 PM
06/28/11 09:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Sounds about right, my 38 Plymouth had about that many leafs, too. The tin cover was to hold the grease in, you were supposed to grease the leafs every so often, if it's wasn't 105 out I would get in the attic and dig out my FSM for the 38.
Don't be the exception.
Re: Rear leaf springs [Re: 36PLYM] #1020381
07/03/11 01:45 AM
07/03/11 01:45 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
do you meen 10 full length leafs ?? im going to ask a friend to count his,,,they use to be my orignal 1940 leafs,,and they would be the same as yours,,,i now run posie,s super slide leafs,,,car sits 1 1/2 inch lower and rides nicer
2015 cherokee
2013 R/T classic
Re: Rear leaf springs [Re: fstfish66] #1020382
07/03/11 10:43 AM
07/03/11 10:43 AM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
At the rearend U bolts there are ten leaves stacked up.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Rear leaf springs [Re: 36PLYM] #1020383
07/04/11 04:02 PM
07/04/11 04:02 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
wow sounds like a lot to me,,im waiting on myu friend to get back to me on his leaf count,,
2015 cherokee
2013 R/T classic
Re: Rear leaf springs [Re: fstfish66] #1020384
11/08/11 01:24 AM
11/08/11 01:24 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
car must have belonged to a moonshine runner---heavy springs to carry the load---bob
