Anyone ever disassymble seat rails? #1020157
06/25/11 10:23 AM
06/25/11 10:23 AM
a cornfield near you
BlakDak Offline OP
BlakDak  Offline OP
if so, hows it done?
are they a pain to get back together?
Re: Anyone ever disassymble seat rails? [Re: BlakDak] #1020158
06/27/11 11:54 AM
06/27/11 11:54 AM
BlakDak Offline OP
BlakDak  Offline OP
bump
Re: Anyone ever disassymble seat rails? [Re: BlakDak] #1020159
06/27/11 01:08 PM
06/27/11 01:08 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
It is not a difficult job. Remove the springs, then remove the bolt retaining clips from the bolts that mount into the bottom of the seat. Extend the track fully in one direction. There is a factory hole on the top of the guide. You can use a small screw driver to help move the metal (70-71) or nylon (72+) bearing guide out. Extend it in the other direction while trying to keep the metal/nylon guide from going back the other way. It will be clear when you try it. You can get new bolt retaining clips at any hardware store, so just cut them off.
Re: Anyone ever disassymble seat rails? [Re: Slotts] #1020160
06/27/11 03:01 PM
06/27/11 03:01 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
You may notice also that at one end of the track , the lip has been
bent upwards. This is to prevent the inner bearing from rolling out if the track is
extended too far.
Jules
Re: Anyone ever disassymble seat rails? [Re: JulesdaWiperman] #1020161
06/27/11 09:39 PM
06/27/11 09:39 PM
BlakDak Offline OP
BlakDak  Offline OP
Thanks for the reply's, I should have clarified, that these are 67-68 vintage seats, but I bet they are pretty much the same.
As always this is something I've never done before, so I thought I'd ask.
Perhaps I'll practice on my Dakota first, those tracks are readily available
