Re: Charging system problem - DIM lights and dead
[Re: aar1]
#1020143
06/25/11 10:46 AM
06/25/11 10:46 AM
RapidRobert
do not check the charging system by taking off a batt cable while running to see if it keeps running. (1) take off both alt female field wire connectors (2) eng at a fast idle (3) w jumper wires w an alligator clip on each end jump from the batt neg post to either male alt field wire terminal (4) w another jumper wire jump from the batt positive post to the other male field terminal for 3 seconds max & if the alt kicks in (You'll feel/hear the eng slow slightly but markedly) the alt is good & it's a field circuit prob but 1 thing at a time. Do have all light bulbs/accessories off when you do this "full fielding". Holler back & we'll go from there
[Re: aar1]
#1020145
06/25/11 11:00 AM
06/25/11 11:00 AM
RapidRobert
yes it'll run if the alt is putting out but the voltage spikes may fry some electronics in the alt. It won't happen every time & I admit I've done it but I do not like to tempt Murphy's law & "full fielding" it takes minutes & some made up jumper wires w alligator clips on the ends are very usefull to have around (make a long one to reach from the batt neg post to the tank sending unit) which is unrelated to your current prob.
[Re: A12]
#1020147
06/25/11 11:09 AM
06/25/11 11:09 AM
RapidRobert
yes check the charging voltage at the batt terminals at a fast idle w lights/heater on then check charging voltage at the alt batt stud/case & see how much drop you have in the system EDIT I assumed that he did not have a VOM at his disposal. OP, if full fielding does nothing pull the brushes & see if all looks good
[Re: aar1]
#1020150
06/26/11 11:01 AM
06/26/11 11:01 AM
RapidRobert
K.I.S.S. rarely fails ![](/ubbthreads/images/graemlins/blush.gif) . Glad ya got it
[Re: mikemee1331]
#1020152
06/26/11 11:26 AM
06/26/11 11:26 AM
RapidRobert
that's an acronym for "Keep It Simple Sam"
