Back to basics... spark plug gap? #1020091
06/25/11 08:00 AM
06/25/11 08:00 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Hi All,
Just had to clean up some mildly-fouled plugs (old gas and lot's of idling), and thought I'd regap them.
Reading through this site, I see many, many different suggested gaps. I read that with MSD boxes, gap should be changed. I also read that a test of different gaps had no resultant change in HP.
So, there's a lot of variation for perhaps not much outcome.
So, I turn this to you all for your opinions.
I've been gapping my plugs at .030
I've got a 10.4:1 505" RB with E'brock heads, a 0.587/0.593 287/294 cam, M1 intake and 1050 Dominator.
MSD 6AL box, MSD Blaster 2 coil, MP distributor and NGK BCP6ES plugs.
For street and strip, what would you gap them at?
Cheers!
Re: Back to basics... spark plug gap? [Re: Damned67] #1020092
06/25/11 09:22 AM
06/25/11 09:22 AM
ill
dennismopar73 Offline
ill
i set mine at 35 gas / 40 alcohol
Re: Back to basics... spark plug gap? [Re: dennismopar73] #1020093
06/25/11 09:39 AM
06/25/11 09:39 AM
gregsdart Offline
gregsdart  Offline
35 is fine, might try on heat range higher, if there are no signs of other problems.
Re: Back to basics... spark plug gap? [Re: dennismopar73] #1020094
06/25/11 09:42 AM
06/25/11 09:42 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 440 with MSD and 12.5 domes, 1050 Dominator and Stealth heads I run .040.Its street driven and no problems.My sons 413 with MSD same gap.I run NGK plugs and they seem better than the Autolites I was running.Rocky
Chrysler Firepower
Re: Back to basics... spark plug gap? [Re: therocks] #1020095
06/25/11 10:18 AM
06/25/11 10:18 AM
PA
moparacer Online content
moparacer  Online Content
PA
I think for the most part all a wider gap does on a NA engine is work the ignition system and wires harder.
I seen a car a few years back that wouldn't run with a .040 gap and was fine at .035..
I run mine at .035 on gas and tightened it up to .030 when I put alky on it.
Blower, turbos and NOS are a different story.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Back to basics... spark plug gap? [Re: moparacer] #1020096
06/25/11 10:39 AM
06/25/11 10:39 AM
Lehigh Acres, Florida
rickstershemi Offline
NGK's @ .035 right out of the box....MSD-7AL2
Rickster
Re: Back to basics... spark plug gap? [Re: gregsdart] #1020097
06/25/11 10:45 AM
06/25/11 10:45 AM
ill
ill
sorry should have said i run 35 on gas / 40 on alcohol but i change the plugs for alcohol, heat range is diff and alcohol being more violent, i change the gap
hi rick hows the car comming along ? are you done yet??
Re: Back to basics... spark plug gap? [Re: Damned67] #1020098
06/25/11 10:45 AM
06/25/11 10:45 AM
Az
Crizila Offline
Crizila  Offline
Az
Hi All,
Cheers!
The wider the better - as long as your ignition system is up to the task of lighting them. I'd go for .040"
Fastest 300
Re: Back to basics... spark plug gap? [Re: Damned67] #1020099
06/25/11 06:33 PM
06/25/11 06:33 PM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Thanks All!
I'll gap at 35, and if there's no apparent issues, step it up to 40.
Cheers!
Re: Back to basics... spark plug gap? [Re: Damned67] #1020100
06/25/11 08:32 PM
06/25/11 08:32 PM
Guitar Jones Offline
I gap mine at .045 with a 7AL, 12.3 on gas but mine's a small block with really good chambers and a lot of quench. Very small chamber and tight piston to head clearance. I'd bet I could run .035 with no problem but I figure if I can get a wider gap I'm better off.
Re: Back to basics... spark plug gap? [Re: Guitar Jones] #1020101
06/25/11 08:38 PM
06/25/11 08:38 PM
Iowa
coronetville Offline
Iowa
.55 like the good book says....
Re: Back to basics... spark plug gap? [Re: coronetville] #1020102
06/25/11 10:24 PM
06/25/11 10:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just changed out the plugs in my pump gas 408, 10.8-1, I set the gap at .045". The wife and I took it on a 50 mile cruise this afternoon, all is good.
