Pulsating Oil Pressure #1020035
06/25/11 02:58 AM
06/25/11 02:58 AM
Indiana
W5Duster436 Offline OP
Indiana
Noticed today on my maiden voyage of the new engine that the oil pressure gauge seems to pulsate quite rapidly +- 2 psi or so. I ran either a -3 or -4 line from the block to the gauge and did not purge it. I have not seen this before and just wanted to verify whether the line needs purged or a restrictor or something to keep the needle from vibrating? It's an Autometer Ultra-Lite mechanical OP gauge.
Idle pressure is around 60 psi and running down the road is around 70 psi but the needle just rapidly vibrates.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Pulsating Oil Pressure [Re: W5Duster436] #1020036
06/25/11 09:25 AM
06/25/11 09:25 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Check the oil filter.
Re: Pulsating Oil Pressure [Re: W5Duster436] #1020037
06/25/11 09:34 AM
06/25/11 09:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Check the filter BUT you could use a restriction in
the gauge... dont know about the gauge you have but
a .020 restriction can be screwed in the inlet on
different gauges to take that pulse out... 99% of
the time you are compressing air thats in the oil line
(normal) so no need to bleed that line
Re: Pulsating Oil Pressure [Re: W5Duster436] #1020038
06/25/11 09:51 AM
06/25/11 09:51 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Kyle, you worry to much.
Re: Pulsating Oil Pressure [Re: justinp61] #1020039
06/25/11 10:03 AM
06/25/11 10:03 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I have see this in my car lots of times. 3-4 diff motors over the years..but the same gauge. if you turn the car off and restart it..it would quit.?? worry me at first but after 20 years I don't even think about no more
Re: Pulsating Oil Pressure [Re: justinp61] #1020040
06/25/11 11:03 AM
06/25/11 11:03 AM
Indiana
Indiana
I know.. LOL
'71 Dodge D100
'70 Dodge W100
Re: Pulsating Oil Pressure [Re: W5Duster436] #1020041
06/25/11 04:35 PM
06/25/11 04:35 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The motor's just letting you know that its heart is beating and the gauge isn't stuck!
If it starts oscillating by a few more PSI I'd guess at a bypass issue or a filter issue after I'd bled the air out; the gauge in my Hemi car has been oscillating like yours for years but has had no problems; it runs a pretty large line. On my other cars - which have smaller lines - the gauges are steady.
Re: Pulsating Oil Pressure [Re: topside] #1020042
06/25/11 07:19 PM
06/25/11 07:19 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
With that big a line to the gauge, you are just seeing the pressure relief valve working.
Kevin
